Painting case
Virgorising
4,470
All I have ordered so far is the mobo so not in a huge rush.
Wave not way dumb phone...
I sent them a sample and they said it was called purple wave.
Wow. This is a whole subculture!!
Again, jus make sure this don reduce the diameter of any screw holes or other tiny openings too much, cause power coating is electrostatic and permanent.
13,804
I recently painted a beige server rack black. I used fairly standard primer and standard paint, and paint brush. It actually turned out ok. I did two coats.
Before:
Virgorising
4,470
He'll have a open end of the week next week
I like it! Confirms he is real deal capable pro......with lots of projects. :)
I think I wouldn't do the inside.....again, to preclude messing up screw holes, etc. Are you planning to?
Starting with boards, internal components are often not very tolerant re wiggle room.
Can't wait to see images of the Royal Rig finished!
