Pain in my knee while running
Status
Not open for further replies.
KingGheedora
3,248
For those who haven't been reading my workout log thread, I've been running on and off for the past 5-6 weeks. First 2 weeks were on a treadmill and mileage was about 1.5 miles per run. Took 2 weeks off due to rolling my ankle (not while running), and then started running outside. I went straight to 3.3 mile runs on pavement, did it one week, took 2 weeks off, then did it last weekend and then today.
During today's run I started feeling a dull pain on the left side of my left knee. It wasn't sharp, and I was halfway through my run so I kept running through it. Is this something that I can expect to go away? What would cause this, and is there a way to prevent it.
bossman34
65
Which ankle did you roll? How bad did you roll it? Was it still sore when you started running again?
I ask because if it wasn't completely healed you may have been unconsciously compensating which can cause problems elsewhere in the kinetic chain.
Otherwise, proper stretching is a good place to start. Tight leg muscles, especially the IT band, can cause knee pain in runners. Try a combo of foam rolling (self myofascial release) and good ole static stretching.
Redfraggle
2,413
Could be overcompenasating as bossman suggested, but could also just be your body adjusting. That happens. I used to get awful aches in my hip flexors until they strengthened and it stopped. Could be your shoes, too.
Mar 22, 2002
10,483
32
I'm glad that for once all I have to do is type: "This."
And as RedFraggle said - it may have a lot to do with your shoes... which is why I run barefoot... Well, essentially. Problem solved :p
InflatableBuddha
7,416
Running on a treadmill gives you an (almost) perfectly smooth, level surface. The outdoors, whether on roads, trails or grass, is almost never level, so your body makes micro-adjustments whenever you encounter bumps or uneven surfaces.
If the muscles surrounding your ankles and lower legs are weak from disuse (because of running on level surfaces such as a treadmill), you are more susceptible to injury when you switch to running on uneven surfaces.
KingGheedora
3,248
The pain is in my left knee, the ankle I rolled my my right one. It was pretty minor ankle sprain, and almost a month ago now, but I stayed off it for a couple weeks to be safe.
Status
