p6t deluxe v2 and hwmonitor, wrong info?
taggy
have someone here this combination
p6t deluxe v2 and xeon x5650?
VIN1 guess is RAM right? that voltage is too high and it is in automatic
and vin6 is too high too, and it seems is the northbridge
could someone post their hwmonitor voltages, better if have the same build as me, thanks
edit:
manual says this
According to Intel CPU spec, DIMMS with voltage requirement over 1.65v may damage the CPU permanently. We recommend you install the DIMMs with the voltage requirement below 1.65v
my dims are 1.5v, if VIN1 is in 1.736, why they are still working and not burned? i dont understand thanks
taggy
i tryied this
quitted off 3 dims, and left only A 1 B1 C1, still same voltage
should i clear CMOS?
Edit: Cleared CMOS and this happened
taggy
tryied to lock all the voltages in minimal, and still showing me VIN1 1.736 VIN6 1.640 WTF, is hwmonitor failling or 1202 bios failling?
taggy
ok, if someone needs this info, read it..
mostly people between 2009 to 2012 said that P6T and deluxe versions of the board, were a trash
here is the problem
by default settings, everything in auto, if you turn the dimms to 1333mhz you will have a voltage problem in auto ( this could kill your board also your cpu in some months )
then, try to use the drams in 1066 , or manual vcore the dram to 1.52 to 1.62 in dram bus voltage, because in automatic settings, you will damage the board due how automatic sets the voltage
i finally found the solution to the dram bus voltage
and honestly, between 1333mhz and 1066 mhz there is not too much difference, then ill recommend to use 1066
Shmee
8,254
3,142
What is VIN1?
Glad you got it sorted. I have an old P6X58D Premium with an X5660, with 4 DIMMs at 1.5V. Seems channel A is dead on the board, but hey, I got if for free from salvage, otherwise seems fine.
taggy
What is VIN1?
download the asus TurboV_V10204_XpVistaWin7 to check the dram voltage and how bios sets it in automatic
about the other main voltages such as north bridge, south bridge
check in aida 64 motherboard > Bios
based on a german forum they said that vin1 was dram, but it seems that hw monitor dont have any idea about this value because always is freezed for me, even if you change to manual each value in bios
anyway, i detected with TURBOV that p6t deluxe v2 bios at 1333mhz ram was setting in 1.66v the drams, when the motherboard says that dont set it more than 1.64v. in 1033mhz its automaticlly sets to 1.50v
note: do not install at the same time EPU software with TURBOV, if you install one, delete the other, it seems makes a boot startup BSOD
