> yea im hardly a noob and and you falling for the p4 hyperthreading tv commercials isnt my fault either
umm.. there are no "p4 hyperthreading tv commercials"
> show me one single unbiased site that says hyperthreading does help a lot. you cant
first, the burden of proof is yours. i made an observation based on owning and using both daily. you imply i'm lying; you prove it. you can't.
second, your statement speaks for itself. any "site" that says it helps is obviously "biased" in your opinion based on your own words.
at any rate, here's one which someone else states was either biased or ill conceived, however they never offered proof of either:
Several interesting things about this chart jump out after a little study. First, both the top and the bottom data lines are both from runs with the Athlon 64. When WME9 was running, the Athlon 64 averaged less than 4 frames per second. We did see one large spike in frame rate, but the curve pretty much remained under 4 fps for the majority of the run. All three Pentium 4 processors performed more poorly when running Flight Sim 2004 solo, but managed to average around 17 frames per second while WME9 was chugging along in the background. The other interesting data point is that Prescott's average frame rate of 17.2 fps when multitasking was essentially the same as the 3.2GHz P4EE's 17.5 fps. Of course, the frame rate dipped on occasion, but the point here is that Hyper-Threading clearly has a major impact. link
kyle over at HardOCP had similar comments:
Originally Posted by Kyle
Multitasking
Every time I write about how Intel Pentium 4 CPUs with HyperThreading dominate in multitasking, I get mad email from AMD fans telling me otherwise. I have had a Pentium 4 CPU in my main work system, which is used for everything I do including gaming, for a couple of years till back in July. I put in an Athlon 64 FX-53 to compare real-world experiences. The difference in how multitasking is handled is much like night and day. Intel?s HyperThreading makes easy work of multitasking where the Athlon 64 simply flounders. I was used to encoding movies and music while I went about my normal work tasks and the Athlon FX system was having none of that. I found many places where the system would ?chug? due to the CPU handling one task while I had another one I wanted to focus on. Sure, you can go in and change the way the CPU handles the particular tasks you have open, but that is simply a pain to get done every time you want to use certain combinations of software.
Now with all that said, I have gotten very used to the way the Athlon 64 FX handles my daily computing needs and to some extent I have formed my needs around its performance. Do I still want my Pentium 4 with HyperThreading back? Absolutely. I think the Pentium 4 with HyperThreading is the best solution for those people that work with many different applications open at once that can be CPU intensive even when working in the background.
i'm kind of like kyle on this matter - i've gotten used to what i consider it's weakness, and to some extent i've also changed the way i do things around it's behavior. i also have an HT p4 sitting right next to my athlon which alleviates this issue. not everyone has that luxury however.
here's a good example i just ran across in a forum post:
Hyper Threading and System Loading:
Generally speaking, yes, in a multi-tasking environment that isn't I/O restricted (meaning you aren't doing something that slams the hell out of the hard drive), the P4 is going to out-perform the Athlon 64 (or will close the gap considerably if the Athlon 64 outperforms it in these functions when evaluated one on one.
Folding @ Home is actually a fabulous case performance for Hyper Threading and it doesn't require the program to be set in real time in order to see this. Here is what happens:
Take two FAH threads. Comparisons will look like this:
Athlon 64:
Time to Finish a Frame of Thread 1: 2 min, 30 sec.
Time to Finish a Frame of Thread 2: 2 min, 30 sec.
Time to finish a frame of T1 & T2 Simultaneously: 5 minutes
(I am simplifying numbers to make my point).
P4 w/ HT
Time to Finish a Frame of Thread 1: 3 minutes.
Time to Finish a Frame of Thread 2: 3 minutes.
Time to Finish a Frame of T1 & T2 Simultaneously: 4 min, 45 seconds.
The point here is that while the Athlon 64 outperforms the P4 on both Frame 1 AND Frame 2 when evaluated separately, the P4 (thanks to HT) will outperform the Athlon 64 by a small margin when running them together.
Hyper Threading is not the be-all, end-all of performance that Intel's marketing makes it out to be at times, and there are many scenarios where it offers little to no benefit. There are also significant scenarios (DVD encoding, some multi-tasking, 3D rendering) where it offers significant benefit.
again, i agree.. it's not a "be-all, end-all" - i never said it was, but in certain circumstances it is indeed quite beneficial when compared to how the athlon64 handles dual threads.
For the multitasking scenario, we chose to run Norton AntiVirus in the background while using Windows Media Encoder 9 in the foreground to convert a 30-second AVI clip to a high-quality WMV file. We report the time it took to run just the video encode by itself and with NAV running in the background. The results show that Intel's Hyper-Threading clearly pays off. The Pentium 4 took about a minute less time to run the multitasking test than the Athlon 64 FX-51 systems did. Copyright © 2004 Ziff Davis Media Inc. All Rights Reserved. Originally appearing in PC Magazine.
there's but a few statements/opinions offered similar to mine. you have offered
NONE; not even your own observations, only your own biased opinions based on.. i dunno.. you've offered nothing. 'nuff said.
i could continue, but the rest of your post offers nothing more than the same regurgitaged opinionated crap which is hardly worth commenting on.
