That's all good and well but these benches are comparing what? A 1Ghz P3 and a 1.4 Ghz P4?
That's fine, but look at the very first P6 core, the PPro at 150Mhz.
Now they have a P3 at 1Ghz
Apply a similar scale to the P4 and you have it topping out a 10Ghz.
That's an exageration, but really the P4 is maybe not much better than the P3 clock/clock, but when you consider how much trouble intel is having getting anything about 1Ghz out, and how much higher the P4 can go, in the long run (with p7 core revisions) the pentium4 will slaughter the P3. It's hardly fair to compare a beta p7 at it's lowest clockspeed to a super tweaked 6th revison 8th stepping p6 at it maxxed out clock speed. Sure they are pretty close, but it's the potentional that's in the P4 that intel is going for here.
I have many beefs with the P4, it's performance comparison to the P3 is not really one of them though.
- It's price
- It makes the Athlon look conservative in power use.
- It needs heatsinks so big and heavy they need to be mounted to the case
- Only Rambus so far
- The next revision is going to have a different socket.
If you want to pick on the P4, there are lots of good reasons, it's minimal performance gain over the P3 isn't really a good one though.
To answer your question though, i don't really think the P4 can top the Mustang, it seems the Mustang is going to ramp up in speed quite nicely and I really doubt the P4 will be able to keep up with the Mustang at the same speed, hopefully intel will be able to keep a good Mhz lead or the Mustang will clobber it.
<< Maximum PC is substandard single-ply toilet paper. >>
- Modus
Damn right.
