Originally posted by: rogue1979
I don't think it is that bad for AMD. Intel has taken the performance crown, but AMD is still real fast and real cheap, especially when the 1700+ and 2500+ overclocking is considered. Only the few people who will order all the bells and whistles and pay over $2500 for a top of the line system from Dell or other big pc manufacturer will benefit from the performance boost of the 800MHz fsb P4. For most of the people who will order a lower priced ($800-$1500) system with a lower end video card and minimum amount of ram, the performance will be wasted. Us few avid overclockers will have a choice, awesome performance for dirt cheap (AMD), or extreme performance second to none for a price premium (Intel).
Originally posted by: redpriest_
Yes, I think it's safe to say that the 3.2 GHz Pentium 4 is the fastest processor for *most* applications. However, I also think it's safe to say that it didn't get there on its own -- it has the aid of a very good chipset behind it. If the i865/i875 didn't exist, it would have been much closer, and I think the original PR system was meant to reflect that. Since the 3200+ was released before the 3200 mhz Pentium 4, it isn't false advertising.
Also, do you think it's false advertising when a 2600C Pentium4 walks all over a 2800 mhz non-C Pentium4? Platforms change, and AMD isn't going to revise the model numbers of their processors if suddenly, tomorrow, Intel introduces a 1600 mhz chipset.
Consider this - what should AMD do -- release a faster Barton with a faster chipset, or concentrate their efforts on Athlon 64 which will be faster than Northwood when it is released? Which is the better idea? Which has more life expectancy? Barton is just a stop-gap measure until the desktop version of the K8 arrives. We *know* how the Opteron performs. The desktop version of K8 will have advantages that the Opteron will not. (AGP, faster memory, probably faster clockspeed).
Also consider how much speed means to you. If playing at 80 fps rather than 60, or 400 rather than 350 really means $400 more to you, by all means, grab yourself one - I think the majority of people would be willing to compromise a little performance to save a lot more cash.
Hyperthreading does next to nothing for single-threaded applications, and really is only a factor if you run workstation applications that are designed for SMP, or you have a habit of running anti-virus software scans when you are playing an intensive game. Sure, it's a neat trick, but is it really useful or adds to productivity? Probably not.
Moving from 533->800 mhz fsb and the dual channel 400 mhz memory that it entails is *the* primary factor in the Pentium 4's incredible performance.
Originally posted by: orion7144
To add to Duvie's cost break down
Take away his IC7 and get an IS7 savings of ~$40
Take away the 3.0C and get a 2.4C (OC'd to 3.0 easily) savings of another $200 so for about the same cost as the AMD 2500+ system you have an outstanding computer that will beat the 2500+ and has HT.
I bought my IS7 and 2.4c for $270 shipped.
I'm sorry, I have to disagree with you here.
I'm honestly not biased at all, I have both AMD and Intel systems in my apartment. And the AMD systems I have, I love.
For most people I build computers for, I usually end up going with AMD. Because you are right that in the $500-800 PC range, AMD is definitely the best bang for the buck. Get yourself a 1700XP or a 2500 Barton, a Epox 8rda+, and 512MB of ram and you have yourself a quick, stable, cheap core system to build around.
However, I just built a P4 System with the following specs for under $1200 and I guarantee you the peformace won't be wasted. And it will definitely benefit from the performance boost of the P4s 800FSB.
The specs are below, and granted it is no slouch, but it isn't TOP OF THE LINE either. But it does have some pretty good bells and whistles, and it certainly didn't cost anywhere near the $2500 you were talking about.
Core components:
Abit IC7
P4 3.0c
512MB Corsair 3500 XMS (2x256)
WD Raptor SATA HD
128MB Radeon 9500 Pro
M-Audio Revolution Soundcard
52x32x52 Liteon CDRW
Antec Truepower 430 PSU
Chieftec Case
And if you count the dual format NEC DVD burner from the Dell 15%+15%+%5 hot deal I got a little while back, then the system also has a dual format DVD burner for a total of around $1300.
But I'm definitely not trying to start an arguement. Like others have said, both AMD and Intel have their place. Personally I can't wait tell the Athlon 64 debuts. I hope it kicks butt. I like AMD, but right now they just don't have the price/performance crown in the mid to upper range systems.
Originally posted by: Duvie
Fortunately in Toms case he didn't use the 2800+ xp but instead the barton one at 2.083ghz, but you can notice that even in the mp3 maker program the 2700+ and 3000+ which have identical clock speed the scores were about identical....The 2800+ 2.25ghz would have beat the 3200+ in that test....
Tom has more test and doesnt look like in the whole pcture the 2.6c beats the 3200+ but damn it is tight considering the priceon those bad boys AMD truly starts sucking in price performance now in the mid range even...
Originally posted by: shady06
wasnt there something back in the day when tom had some fake p4 2.6 or sumthing like that?
