>>> P4 2.4B <<<
Interesting. I'm not the only one it seems. Any idea what the week was? This is a 3231A416 week 31 Costa Rica. What did you do with the CPU?
I currently have a 2.4 C1 @ 3.006 167fsb Vcore 1.525 that is extremeley stable. Just to see if I could push it further, I pushed it to 3.204 and 178fsb. P95 failed immediately. Increased Vcore to 1.575 and P95 failed after one minute. Increased Vcore to 1.625 and P95 ran all night. Temperatures increased 2-3*C, but it was definitely stable.
CPU is a week 1 Malay batch# Q301A184
Originally posted by: Valvoline6
Just like you oldfart I had a C1 2.4b before the one I have now and it would only do 145 fsb. It did that at default voltage and wouldn't go any higher, no matter what.... It hit the wall. Wouldn't even do 146....... The thing couldn't do 5 minutes of P95 above 145...
What is your fsb doing now on the new chip??? Have you got past same 145fsb??? Was the asus p4pe the same board for both chips???
Also was evrything else the same...Ie ram (# of sticks, speed, etc), power supply unit???
I just ran P95 all night (9 hours) at 150 fsb. Before that I ran it for about an hour and got an error. I had my memory at 2-2-2-5 @ 400 mhz. I changed my timings to SPD 2-3-3-8 and then P95 ran all night. I am a little disapointed that Corsair PC3200 can't do 2-2-2-5 @ 400... I will run memtest86 but if it throws an error on P95 whats the use. 🙁
I just started P95 @ 160 fsb..... lets see if she can make it (memory at 400 mhz, timings by spd).
BTW: How many hours of P95 tortute test is needed at minimum to declare stability? An excepted standards out there?
Did you try 2-2-2-6? My XMS3200C2 works perfectly @ those timings @ DDR400.
Originally posted by: Jgtdragon
My experiences with c1 is that once you hit the wall with default voltage, it won't go much further. No matter what voltage you throw at it.
That is is same here.
Once you max the chip at default, you can only get maybe 4mhz more with 1.68-1.70vcore.
Anything above 1.68-1.70v makes no difference at all.
Thugs
That chip you got is probably suffering from humidity. 🙂
I am after being in Orlando for the past 4 days. 😉
Edit: My two 2.4b's stable running Prime95
Wk43-2002 172fsb 1.68v Philippines
Wk04-2003 176fsb 1.68v Malay
The Malay will boot and run 179fsb but not 100% stable.
jhites ~ hope ya had a good time! 😀
yea lots of humidity, but no static 😉
ive only had 2 C1s so far and both acted quite differently from B0s.....
(1.65v bios)
2.0A benchmarked 3200mhz ~ p95 stable 3000mhz
2.4B benchmarked 3060mhz ~ p95 stable 2880mhz
the older B0 chips didnt have that far of a spread between benchmarks and p95 😕
My old C1 is a week 33 Malaysia, Pack date: 10/22/2002. I still have it, will probably sell it. My new chip is at 160 fsb so far, stable after 5 hours of P95. More P95 to come over night tonight. Both chips were on my P4PE, everything the same. I like the P4PE, very stable and lot's of OC features. I have had zero problems with it.
I had one report of XMS 3200 being stable above 400mhz at 2-3-2-5, and now yours at 2-2-2-6. I will test both.
Ive had two SL6EF cpus - week 38 and week 44. The highest stable either would
go is 161 fsb (1.65V). Both could boot at 166 but would crash when benching.
Both were tried on two different boards - a BE7 and an Epox 4pead :-(
i had to go 2-2-2-6 on the p4g...it gives errors with 5...hopefully it'll work for you.
Well my P4 2.4b may have topped out. Set at 160fsb did P95 all night with DDR 427 2-3-2-5. I went back to relaxed memory timings / speed, went for 164fsb and got an error after 11 min. of P95. Going to try 162... BTW is 2-3-2-5 @ DDR 427 pretty good? Maybe this stick isn't so bad afterall. Going to try Thugs 2-2-2-7 timings too..
I'm not too interested in overvolting the cpu. Really want to keep it at default..
That is very good considering when you usually run your ddr that high it drags on the vcore required to run it...I bet if you turned it to 1:1 ratio you would likely make it to 3-3.06ghz at default like me.....
In the past when I ran my 1.6@2.66 w/ 440ddr it required .05v more vcore to run prime95 and memtest....different mobos will react differently but I figure .03 to .05v to get stable....
My quandry will be...hopefully...
2.4@3.33ghz w/ 370mhz cas 2,2,3,5(turbo) @1.68v
or
2.4@3.166ghz w/ 440mhz ddr cAS 2.5,3,3,6 @ 1.58V
I will need to test to see if the bandwidt of the 440 at cas 2.5 can outweigh the slower ram but 166mhz more cpu power and ofcourse much more aggressive cas 2 timing...
I got a BO stepping ordered it in Jan thought for sure I'd get a C1 but no luck
It's a SL6EU pack date 11/22/02 Manufacturing Plant ?
System performs pretty well well at 150 (2700) but become unstable over that and fails at 160.
Still can't complain for a $160 cpu.
I may put it in my wife system and try again for a C1.
What you all think I'd have better luck with another 2.4 or try a 2.53
How do you tell where the cpu manufacuter at?
Here's all the info on the retail box
Prod Code:BX80532PE2400DSL6EU
FPO Batch# 3234A696 MM#848392
Version # R97227-01
Version # R97227-01
You have a Week 34 - 2002 chip made in Costa Rica
I think I am on my way to Frys to pick up a 2.53 and 2.4b just to have
something to play with today. 😉
