I'm sure there wouldn't be an issue with the physical fit (I can't think of any video card that extends over a 3rd slot), but I'm more concerned if there's a partial blockage of the fan and the effect on temps.Originally posted by: Skott
One poster over at HF says he has a 8800GTX video card and a 7.1 PCI card on his G33M-DS2R mobo so I'm gussing there wouldnt be any issues with a X-Fi card neither.
I think it would depend heavily on exactly which PCI sound card we're talking about (and if it's a full height one). Also, the 8800 GTS is pretty short (comparatively, that is :laugh: ), the GTX is significantly longer. I'm not sure of the size of the 2900s, but I think they're between the GTS and GTX.
Anyways, if I moved my Audigy 2 ZS into my 1st PCI slot, it would extend to almost exactly halfway across the GTS intake hole. There isn't any physical contact between the video card and sound card, but there could be issues with the airflow. I'm not sure of the size of the X-Fi, but I would be surprised if it were smaller than the Audigy 2 cards.
Course, the GTX may be so big that no PCI card in existence is long enough to obstruct it
EDIT: I found 10.5" on the GTX and 7.2" on the X-Fi (XtremeMusic version). I don't own either, so other people are going to have to verify if those numbers are right. So that's 3.3" inches from outer edge to outer edge. Which would be fine if the HSF on the GTX extended all the way to the edge, but it may not from the pictures I've seen.
