P3 700 -- $192 FROM ONVIA ! - repost of a hot deal - warehouse updates
$, the reimbursements are processed at the end of the month, but the check isn't sent until the middle of the month (or even later). I got my last check sent on the 16th of June.
so anybody getting chips from Pa now
i havent ordered in a while
so whats the pack date
btw i know all yah are happy 🙂
good luck on the journey to 933
Quick pointclick question:
I show a pending $21.00 check from them on their web page. Does it really have to be over $25.00 before they'll send it? Or will they send it regardless?
your balance goes to zero if you had less than the purchase price plus 10 % in your account, but you will not get a check until your reimbursement (checks pending) are over $25.00. A description of how it works can be found here:
http://www.pointclick.com/example.jsp
That should answer ALL the questions about PC Reimbursements -- EXCEPT NOTE THE NEW POLICY IS YOU MUST SUBMIT THE CLAIM WITHIN 5 DAYS EFFECTVIEVE AUGUST 1ST.
i think its time to start a new thread....
anyone know if they make slot 1 700's? i'm anxious to try out a slot 1 version of the famous cb0 700 and see if it's got the same oc abilities. gimme a thread at onvia if you see it.
edit: i meant slot 1's at onvia.com.
i know... i just wanna use a slot 1 if at all possible. i don't need to get it to a gig...it be nice if it could but i don't need it.
ok BiggieN --- A MSI slocket at onvia is like $10.83 with free shipping...
WHY do you want to test the waters with a slot 1 version? The slot 1 versions ALWAYS suck ASS majorLY!
anyway, back to the regular programming...
How soon till the cC0 stepping 700's come out? the 1.133GHz P3 is or will be available soon and it is of the cC0 stepping.
