Oy. Help me diagnose my New Years screwup..
UglyCasanova
19,275
1,361
New problem. My USB connections aren't working at all. This means no mouse or keyboard. This happened right after I installed the USB driver on the asus cd. I can't use the mouse, but I can use my iPad because I installed air mouse. Problem is when I go to install something like new drivers the air mouse program doesn't work because of the "are you sure you want to install" pop up.
How do I fix this? Delete all of the USB drivers?
Ketchup
14,553
248
Might help. But check the BIOS. Your mouse and keyboard should still work there. Make sure you have made the proper selections.
I suppose you have tried plugging/unplugging/diff ports/reboot.
I don't remember running into that problem on my current board. I have in the past, and one of the above always fixed it.
UglyCasanova
19,275
1,361
I uninstalled the Intel software in add/remove programs and it did the trick.
Sucks I had to buy a new motherboard but all told I'm only out $130, it could have been much worse. :)
