bystander36
- Apr 1, 2013
- 5,154
- 132
- 106
What??AA is now a 'specialised feature' akin to PhysX? You have to be joking?? I've been using AA for over ten years as well as anisotropic filtering (I imagine you consider that a 'specialized feature' too). Don't tell me, as far as you're concerned a full colour (32 bit) display is a 'specialised feature'.
I view AA more like a resolution setting. These are generic settings on the graphics card. Some games just allow for what ever your graphics card has, while others may tune it down. I personally find 4x MSAA to be all you ever need for any noticeable benefit. It is also a setting you can force higher from your graphics control panel. You also frequently have different AA choices with different weaknesses and advantages, so which is the "maxed out" AA choice is a little difficult sometimes.
I realize some include those into their "maxed out" settings, so I always qualify it. I believe when saying "maxed out", you also need to include resolution and AA settings to avoid confusion.
Crysis 1, Dirt 2 and other games, even offer different AA settings depending on the graphics brand you use, so that can make things a little tough to compare sometimes.
