Originally posted by: GuitarDaddy
I've yet to see one proven prime stable for 12/24hrs any higher than 4.2ghz.
How about a 10 hour? my final clocks are 4.25 @ 1.392Vcore :T
Originally posted by: bryanW1995
ok guys, I have a confession to make. I bought 4 vapochills last night and stacked them on a Q6600 b3. well, actually one of them is on top, then there's one for each side of the q6600 except the part on the bottom (facing down towards the video card. my cpu won't boot to windows at over 5.2 ghz, is this normal? I spent good money for this cpu and I'll be damned if I'm going to settle for only 5.2 ghz. oh yeah, all of this is running an an ip35-e with 17gb of rdram.
Originally posted by: BigMoosey74
So back to the 1.79V....did it burn up yet? Lets just use this as an extreme case to see how long these things last over 1.5V
I think you missed my post where i said i lost a Wolfdale. E8400 ES. @ 1.57Vcore in a span of 1 month loaded.
Originally posted by: Owls
How fast can that QX run at 1.45-1.5v?
Originally posted by: nomagic
Please excuse my ignorance. I feel ashamed to ask, but my curiosity got me. What kind of finance machine needs to be overclocked so much at the expense of stability?
Isn't it a consensus that for finance machines (or any mission critical machine), stability is far more important than speed?
If serious business is involved, wouldn't you want to rent or buy a super-computer? Even building a computer cluster would be a better choice depending on the application. Why build a enthusiastic machine for finance use?
"Reliable solutions from a trustworthy tech company" <- my 2cents...
*sigh* i brought this arguement up, so lets not continue with this:
Here is the reference: Pg.2
http://forums.anandtech.com/me..._key=y&keyword1=QX9770
Originally posted by: Rambler358
Okay, first post here so go easy guys! I have a QX9770 which I got a very good deal on. The mobo is a EVGA 780i FTW, and my system is water cooled. My PC, aside from normal PC activity - email, web surfing, etc. is mainly used for gaming and 24/7 Folding.
I've gotten 3.8GHz stable (IBT 9-passes) with a BIOS CPU voltage of 1.400v, and the FSB/VTT at 1.25v. I'm trying for stablity at 4.0GHz, but it doesn't look like I'll be able to do it with IBT (Intel Burn Test). It can pass OCCT and Prime95 though. My concern is the BIOS CPU voltage - it needs 1.50v and a FSB/VTT of 1.325v to get OCCT stable. At idle, my vcore is around 1.46v and under Folding load it's around 1.38v. Core temps stay under 50*C when folding. But is my CPU voltage (BIOS 1.50v) too high for 24/7 use and this CPU? Thanks in advance for any info!
Thanks for that info. Looks like it's back down to 3.8GHz for me then. It's just that I've been getting conflicting info on CPU voltage, but consistant info that FSB/VTT should never go above 1.40v and preferably be kept below that. Some have said to stay below 1.60v on the CPU in the BIOS, and others like yourself have stated 1.40v. Reading Intel's specs for this CPU, it does seem the 1.40v mark is where I need to be and not higher if I plan on keeping this chip for a while. Thanks again.
Thanks again Ocguy. Yeah, I definately wouldn't put it at 1.6 but some have also said I'd be safe with 1.5. I'm just going to stay at a 3.8GHz OC and keep BIOS CPUv @ 1.40v. There's not too much of a difference between 3.8 and 4.0 from I've seen anyway. And although I paid no where near $1400 for this CPU, it was still enough for me not to want this chip as a keychain. 😉Originally posted by: Ocguy31
Its what actual voltage goes through your chip that matters. If you put 1.6 through a 45nm quad, that is a timebomb. Whoever told you that is trying to give you a $1400 keychain.
Originally posted by: Idontcare
{snip}
{snip}
You seem to be a great person, but you of all people should know better - I'm going to laugh my butt off if your OC'd CPU ever gives an incorrect result costing you millions of dollars 🙂
