- Nov 6, 2005
- 20,984
- 3
- 0
As I also read the Greysky guide, I am not sure if I have this right or not.
"3. Memory
You will need memory that can keep up with your overclocked system. Again, I?m not going to keep a list. You?ll see RAM listed with timings and speeds that I?ll decode for you using the following examples:
DDR2-800 (PC2-6400) 4-4-4-12
DDR2-1066 (PC2-8500) 5-5-5-15
? The first part is self-explanatory (DDR2 memory).
? The number after it is the data transfer rate. Simply divide it by 2 to get the maximum FSB speed for which the module is rated. Example: 800/2 = 400 MHz. Therefore, DDR2-800 can work on systems with a FSB of up to 400 MHz (anything more and you?re lucky). "
So am I correct, given that I now have PC5300 memory, and 5300/2=2650 , meaning that existing memory would keep up with an up to a 265 MHZ front side bus speed. And then given my locked multiplier is 12.5, that in theory I could use a bus speed or 265x12.5 to hit a chip speed of up to 3.3125
GHZ without changing memory or using a memory divider? Or am I missing something here?
"3. Memory
