If I am overclocking a Radeon 9800 Pro with stock speeds of 380/340 is it important to keep the difference between the first and the second number 40 (380-340) or does that not matter?
I am using ATI Tool, should I only be bumping the mem clock and not the core clock? Should I go as high as I can get until it becomes untsable/produces artifacts or is there a certain number I should stop at. Note: I am not using extra cooling and don't want to fry the card 🙂
