Hey guys.
I am currently attempting to overclock my i7-9700k.
Here is my current specs:
CPU: Intel Core i7 9700K / 3.6 GHz
CPU Cooler: NZXT Kraken X72
MOBO: Asus Rog Strix Z390-F GAMING
GPU: Asus Rog Strix RTX2070 O8G GAMING 8GB GDDR6
RAM: Corsair Vengeance RGB 16GB: 2x8GB DDR4 3000MHz DIMM
SSD: Samsung 970 EVO Plus MZ-V7S500BW 500GB - PCI Express 3.0 x4 (NVMe) - M.2 Card
HDD: Toshiba P300 3.5´´ 2TB - 7200rpm 64MB SATA-600
PSU: Corsair RM750x
CASE: NZXT H series H700i Window Black
Attempt 4.9GHz:
Multiplier: 49
AVX Offset: -3
XMP: XMP 1 Enabled
MCE: Disabled
SVID Support: Disabled
BLCK Aware Adaptive Voltage: Disabled
CPU Core/Cache Voltage: 1.350
- Cinebench r15 - Passed.
- Realbench - Passed.
- Prime95 - Passed.
- Highest temps was 85c.
Attempt 5.0GHz:
Multiplier: 50
AVX Offset: -3
XMP: XMP 1 Enabled
MCE: Disabled
CPU Core/Cache Voltage: 1.360v
CPU Load-line Calibration: Level 6
CPU Current Capability: 170%
Long Duration Package Power Limit: 4095 (max)
Short Duration Package Power Limit: 4095 (max)
CPU Core/Cache Current Limit: 255.75 (max)
- Prime95 - BSOD after 2 minutes.
Failed.
2nd attempt 5.0GHz:
Multiplier: 50
AVX Offset: -3
XMP: XMP 1 Enabled
MCE: Disabled
CPU Load-line Calibration: Level 5 (Changed)
Changes: Only changed LLC from Level 6 to Level 5.
- Prime95 - Worker stopped after 3 minutes, no BSOD.
- XTU - Passed.
If you need some Min/Max/Avg screenshots of temps/voltages let me know, apparently cant paste them in this thread.
So a few questions here.
I've heard/read that if a worker stops in Prime95, it means your overclocking is unstable. Is it worth trying to let it finish and see what happens or pointless ?
Also i noticed when using XTU, that every 10 sec, 1 or more cores drop to 4.7GHz for a split second and go back to 5.0GHz. Is that due to AVX instructions coming into play or is it my cpu throttling? And how to fix it if needed.
Temps are fine, hitting max 82c on 1 core, rest high 70's.
VCORE is at 1.360v and droops to 1.332v and never go over 1.360v.
Thanks in advance, and sorry on my rookie questions & mistakes.
PSU: Corsair RM750x
Attempt 4.9GHz:
Multiplier: 49
AVX Offset: -3
XMP: XMP 1 Enabled
MCE: Disabled
- Prime95 - Passed.
Attempt 5.0GHz:
Multiplier: 50
AVX Offset: -3
XMP: XMP 1 Enabled
MCE: Disabled
Failed.
2nd attempt 5.0GHz:
Multiplier: 50
AVX Offset: -3
XMP: XMP 1 Enabled
MCE: Disabled
- XTU - Passed.
