OVERCLOCKING HELP
luniz978
61
ASUS "P5AD2-E Premium" i925XE
Intel 3.6 chip that i got for free, so i have to use intel you amd fans...
OCZ Performance Series 240-Pin 512MB x 3 = 1.5 gig DDR2 PC2-5400
Leadtek nVIDIA GeForce 6600GT Video Card, 128MB GDDR3, 128-Bit, DVI/TV-Out, PCI-Express, Model ""PX6600GT TDH Extreme"
Thermaltake VA4000 Series SViking VA4000BWS Black Mid Tower Case With fan speed controllers & Temp. LCD Monitor with alarm
Thermaltake cpu fan as well
I can only overclock 5%, why won't my comp let me boot at a higher overclock
yliu
77
A couple of possible reasons:
1. your motherboard doesn't have a working PCI lock
2. you need to loosen the timing on your memory or run the memory at a slower speed
luniz978
61
how would i find out for question #1?
How do i loosen the timing or run the memory at a slower speed?
luniz978
61
MisterChief
Banned
Dec 26, 2004
1,128
I'm not sure if it's supported, but MSI's CoreCenter utility will help you with your overclocking. You can get very high, very stable speeds, and CoreCenter allows you to tweak the AGP, Vcore, and RAM voltage. Works for me!
