Overclocking Help, XP 2100+ Tbred B
dxkj
MSI KT6 Motherboard (KT600)
Crucial PC2100 256MB
XP 2100+ Tbred B
I've had this chip for a while so I know it will do 2.1ghz without breaking a sweat..... but the max multiplier that it will take is 13 I believe....
Since my RAM wont go over 133 (Tried OC'ing, it just hates anything faster), I can;t get the processor speed above stock. Is there some way to get the Multiplier to go up to 14,15,16,17 etc on this board, or do I need to cut, or connect some bridgest.
It's been a while since I've had to do any chip modifications, got spoiled by fast ram, and easy boards.
There is a wire pin mod in the cpu forum if you do a search for it....Just be in last week or so...If the board bios does not suport it it may be useless...
