cubeless
- Sep 17, 2001
- 4,295
- 1
- 81
READ THE THREAD , HE HAS A AFTER MARKET COOLER.
SOrry for caps
he say he owns a hyper212, not that it's installed on this chip...
u may cap some more now if u like... ;p
SOrry for caps
yes the hyper 212 is on the chip. also, he cant get the fsb past 250 without instability at 1.5 volts.
there's no 8x or 9x for the HT speeds. it just gives me a bunch of frequencies ranging from 1200 to 2000. and whichever oen i set it at, it's always higher. also, how far do i increase the voltage on the ram and the northbridge? forgive me if i sound noobish.250? Tell him to drop the HT link to 8x. 250x8 = 2000 , you wanna try to keep the HT at 2000.
from 2.6 to 3.3 is fairly good overclock.
Let me know if that don't work and mabe we will give the Northbridge a voltage bump along with the ram.
so is it just safe to put all of the voltages to their upper limit? and also, let's say i set the HT speed at 2000mhz in bios, it shows up as something higher in cpu z.you tick up voltage until you get stable at whatever clock you choose... all of the bits and pieces have their upper limit (like ddr3 ~1.65, etc...)... do some searching for your nb, etc...
don't know if that mobo locks the ht, it could be the base that you start from... does the bios show what the ht is running? maybe cpuz does?
So revised:It's taking shortcuts but yes, except step 1) Increase CPU voltage to 1.45 and don't go beyond 1.5 while following these steps.
If you're going this route you might as well set your northbridge voltage no higher than .1 from the default unless you love risk.
The CPU is already running at 1.45 volts. It can't get any higher than 250 fsb without instability. And how do I check the speed of my northbridge? is it there a multiplier for that?I think tweaking other voltages is going into voodoo expert territory. Your list looks good, keep in mind if you aren't quite reaching your target FSB you can set raise CPU voltage within your upper limit and you can run your HT at 1600 or 1800 actual speed.
Edit: Noticed one thing missing, try to run your NB around 2400 actual speed. Just tweak that last so you can correctly judge stability. Final note - run a stability test for a decent amount of time, at least as long as you expect to have the computer on at any single stretch or 24/48 hours if it's a 24/7 computer.
