overclock system... pentium 805
fullmonte
15
ASUS P5N-E SLI LGA 775 NVIDIA nForce 650i SLI ATX Intel Motherboard - Retail
Model #: P5N-E SLI
Item #: N82E16813131142
Return Policy: Limited Non-Refundable 30-Day Return Policy
In Stock
$144.99 -$10.00 Instant $134.99
Update
BFG Tech BFGR76256GTOCE GeForce 7600GT 256MB GDDR3 PCI Express x16 Video Card - Retail
Model #: BFGR76256GTOCE
Item #: N82E16814143049
Return Policy: Standard Return Policy
In Stock
Mail-in Rebate
$142.99 $142.99
Update
Intel Pentium D 805 Smithfield 2.66GHz LGA 775 Dual Core,EM64T Processor Model BX80551PE2666FN - Retail
Model #: BX80551PE2666FN
Item #: N82E16819116001
Return Policy: Processors (CPUs) Return Policy
In Stock
$92.00 $92.00
Update
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X2048-6400 - Retail
Model #: TWIN2X2048-6400
Item #: N82E16820145590
In Stock
Mail-in Rebate
$212.00 $212.00
Update
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-2GBNQ - Retail
Model #: F2-6400CL5D-2GBNQ
Item #: N82E16820231098
In Stock
$214.99 -$30.00 Instant $184.99
Subtotal: $766.97
Select All - Select None
Markfw
May 16, 2002
27,427
16,294
Yes, dump the 805 and get a core2, any core 2. And forget that motherboard. If you are in a pinch for money, get a Gigabyte S3 for ~108 last I looked.
fullmonte
15
ya i am scraping for cash. i just read a little about being able to oc the 805 to 4ghz. thought it would be the cheapest way to go. ill check out the core 2 thanks.
Stumps
7,125
the 805 might be a good Idea if you live in the Antartic...you won't need a heater then, but otherwise just get a E4300 and GA-965P-S3 if you want to overclock on a budget...much faster.
NamelessMC
466
My ex girlfriend's rig, I almost went with an 805 and a DS3 965P because I figured, "I could dump the 805 and get the 4300 when the price drops to $113", but there's always complications with "planning" on getting a better CPU. I ended up dumping the OCZ GameXStream 600 and went with this cheap $28 CoolMax 500 watt power supply, and I used the $100 I saved to get a Core2Duo because I knew that as long as I didn't over-clock, the cheap PSU would last til I could scrape up the money to get a tier 3 PSU. The thing is, when I went that option I only lost $28, but if I went with the 805? That'd be $92 I lost forever, or even as much as $40 because I wouldn't sell an 805 used for anywhere more than $50-55, especially if I start selling it when Intel drops the price on 915/925's to 70-80$. I recommend you get a cheaper GPU, something like a 7300GT or 7600GS, and wait until the 8600GT comes out and save up until then. You're on a budget sure, but doesn't mean you shouldn't get good deals and good parts that last a while.
fullmonte
15
Ok... i think right about the e4300 w/ GA-965P-S3 mobo. any other suggestions on ram or a dif motherboard?
im a little new to this whole oc deal. i have a barton 2500 @ 2.2 right now. thanks
