Overclock has never been "stable" under stress tests, but why should I care?
Zensal
740
Originally posted by: VirtualLarry
Originally posted by: Lothar
Do you test your stock speed system to make sure it's Prime95, Orthos, OCCT, Intel Burn Test stable for 24 hours?
What if you find an error running at stock settings? Do you RMA cpu/motherboard to Newegg/Intel saying it's defective because it wasn't Prime95/OCCT stable for 24 hours running at stock which could lead to silent data corruption?
Yes and Yes.
QFT.
This is the reason RMA exists. If a CPU or other part can't do math for a few hours on end, then there is definatly something wrong with it. Always do a stock test to make sure the part you bought is working correctly.
JimmiG
2,024
112
Originally posted by: Jumpem
I have thousands of family photos, home video, and some financial spreadsheets that are irreplacable. Could these be corrupted by overclocking?
If so, I don't think an extra 5 fps is worth it.
Ideally, you should have two PC's - one that you use for gaming, overclocking, trying out new beta drivers etc. Then a cool, quiet system running proven, reliable components at their stock speed, with WHQL drivers and only trusted software that you need for productivity, photos etc.
Also, regardless of whether you overclock or not, I do hope you have backups of this irreplaceable data. Otherwise you're guaranteed to loose it all at some point anyway. It's not a question of if the hard drive is going to fail, it's a question of when.
As for corruption, I find that's more likely when you're pushing the FSB or memory too hard, rather than the CPU. An overclocked southbrdige can become flaky, especially when many drives are connected. Add to that mix overclocked RAM sticks that can't hold the data without it getting changed, and you'll get lots of strange crashes and application failures even when CPU usage is pretty low. Of course you can just blame them on Vista like everyone else does, but it's probably a good idea to look into it even if your CPU passes that burn-in test :)
Jumpem
10,757
I only have a single PC. data is duplicated on four drives though. Maybe I'll just go with a quiet and stock i7 860 setup.
faxon
2,109
i test 24hr because im insane, thats why. sometimes when i can, i play everquest2 for more than that amount of time non stop, running multiple accounts to maximize my gains in the time i played during my binge. EQ2 was recently optimized to populate a second CPU core to about 50% load in addition to its primary core it runs on, so during this entire binge, after vent, a browser,WMP decoding FLAC audio files on the CPU, and a combat log parser, my system is running 75-80% CPU load for 24 hours straight. now, sometimes i end up running even a 3rd account borrowed off a friend or guild mate for whatever reason, which easily maxes out my CPU (yes the 4.2GHz quad) and fills my ram (im at 7GB without the 3rd client open, gotta get myself an i7 and 12GB). if im running this kind of load on my system, i dont want it crashing out on me in the middle of something i camped for a few hours to kill just once, or having even a single client go on me, booting my tank or healer out midfight in a situation that could take up to 2 hours to recover from including fight time back to where i was before. so for me, running OCCT for 24 hours straight makes total sense, since even 3 EQ2 clients arent going to put THAT big of a load on my CPU (though it comes pretty close), and having my rig crash out on me sucks major sack when it happens. i know some would say "well why not use a second box for that 3rd account), and to answer that i will say honestly i used to, but when i have to alt tab between games it is a MAJOR pain in the ass to do it AND have to move between mice and keyboards to control all 3 characters properly, and using synergy to link it up incurs a delay at times when trying to move quickly between systems. the most effective way is for me to run everything on one box, and as you can see, i simply have to have as much CPU power as i can, despite the fact that the game started development in 2000 and it's now 2009. i wont get into the specifics of the game engine's optimizations more than i already have, but suffice to say it isnt the most stable beast ever when run on an inadequate system, and having my game crash on me while im playing simply isnt fun lol.
imported_Lothar
4,559
Yes and Yes.
Interesting.
Using everything at stock, the only program I've ever been concerned with was running Memtest86 to make sure the RAM is compatible with my system and they're no errors on it.
What if your processor passes a 24hr test but fails a 26 or 31 hr test?
Ex: You were planning to do a 24 hr stability test but you overslept by 3 hours or you forgot to check it before going to work and came back to see it failed on the 26th or 31st hour?
What if your Intel CPU passes Intel Burn test and OCCT, but fails Prime95?
Wouldn't Intel say something like "your processor passed our certified Intel Burn Test. We don't certify them for 3rd party programs such as Prime95 or Orthos." RMA invalidated?
Do Dell and HP accept RMA based on an entire system they're selling failing Orthos?
If so, that would be interesting but I somehow doubt that's true.
imported_Lothar
4,559
Originally posted by: ecvs85
The thing is that by passing the stress test, you can ensure that the data calculated by the CPU is correct, which is critical in certain situations such as encoding, distributed computing, probably excel etc. One of the reason for stress testing is that by passing the test, the cpu will be stable and it would not be a factor in crashing the computer anymore.
It all depends on the end user, if the computer didn't crash and doesn't run data critical applications then go ahead. But if the machine isn't stable Prime/Orthos wise and still using it to run distributed computing software then you'll be doing more harm than good, bad data hurts those projects.
What defines stability for those programs? The standard "no errors in 24 hours" rule being mentioned all over the internet?
Do you increase voltage above the default settings which Intel/AMD engineers already feel is adequate?
Before Intel and AMD release a processor into the retail channels, do they test Prime95 and OCCT for 24 hours ensuring that their processor don't fail a test?
What if the CPU I'm about to order from Newegg/Micro Center passes Intel Burn test, but fails OCCT and Prime 95 running at stock? What should I do?
Also, why stop at 24 hours? Why not 168 hours?
I find the "24 hour" rule being mentioned all over the internet to be completely unnecessary. The most I've ever ran Prime95 for is 18 hours. I'd say about 12 hours is more than enough for my needs.
As is the case with all testing, the tester must first decide what question it is that they want to answer by running the stress test.
If you are running stress tests for arbitrary reasons (some dude on Internet said to run it this long) then you will find the answer to not really address any question you personally might have had.
There are valid reasons for running 24hr tests, that data answers questions that some people want answered. If you don't know the question that is being answered it would be ignorant of you to assume the question itself doesn't exist.
So the question for you is what question do you think you are answering by running an 8hr test, versus a 24hr test, versus a 168hr test? If you know the question you are trying to answer by running your stress test then it is self-evident.
If you aren't really sure why you are running stress tests then the data you are generating by doing so will be rather meaningless and as such you are more likely to conclude the exercise of generating the data is equally meaningless. Your deciding such doesn't actually make it so, just means you are operating within a certain regime of ignorance as to what people intend to accomplish by running longer and longer stress tests.
Those folks are seeking to generate an answer (the data) to a question they have. You might simply not have the desire to answer that question, or you may be unaware that the question exists or that it might be relevant to you.
I ran the stress test to determine stability of my overclocks and was suggested to use those programs to do so. The question I had was for how long? Most people on the internet immediately spit out the 24 hour rule(because they heard someone on the internet say so) without giving any valid reason to it.
I have never seen anyone ever explain the reason for them choosing a 24 hour test over a 12, 16, 48, or 168 hour test.
I stopped prematurely at 18 hours because I asked myself, "What is the purpose for me doing it this long?" I also determined that none of the programs I use would stress the processor anywhere near what these programs do.
Both ATI and Nvidia have labeled OCCT as dangerous for a reason and throttle it when their GPUs detect it.
Also, keep in mind I stopped prematurely at 18 hours. It doesn't mean my computer wouldn't have been 24 hours Prime95 stable if I didn't stop it prematurely. ;)
Some people say you discover 99% of the errors within the first 12-16 hours of running Prime95. I haven't seen any basis for that evidence either.
Based on your posts I've seen in Storage and this section as well, you're very intelligent so maybe you can provide me with your reasons.
Do you personally test for 24 hours?
What questions are you trying to answer that can't be answered by running a 12, 16, 18, 24, 48, or a 168 hour test?
imported_Lothar
4,559
Yes and Yes.
QFT.
The word "few" is subjective.
What qualifies as few?
8 hours? 12 hours? 16 hours? 18 hours? 24 hours? 26 hours? 48 hours? 168 hours?
BonzaiDuck
16,864
2,183
Yo, Vir-Larry, IdontCare and other campagneros.
Here's my two-cents on this, having scanned quickly through the posts on this thread, totalNoob:
I had an E6600 when I jumped to C2D in 2007. This year, I fried the damn thing, but not from over-clocking -- it was a defective PSU.
Going from 2.4 to 3.0 Ghz on that CPU was fairly simple. Some people I saw were pushing it to 3.3 or 3.4, but 3.0 was not much of a stresser for it.
The upper limit of an "operational" voltage range was 1.5V on these 65nm Conroe chips. I'd have to delve further to refresh myself, but that MAY have been the upper limit of a "safe" range, then again -- maybe not. There was an "operational" range, and a "safe" range fell within it.
But 3.0 Ghz was well within the so-called "safe" range for voltage bumps needed to get stability. As I recall, it was well within what Intel had labeled the retail box as "maximum voltage." It would've been "within warranty limits."
You should be able to get total stability on that core using something less than 1.4V -- probably below 1.35V. You could fine-tune further by bumping up the CPU VTT or CPU "FSB" voltage just a tad -- and below 1.4V -- Even the E8x00 Wolfdales (45nm) that I run have the VTT showing 1.28V after I tweaked them to 1.3. Tweaking the VTT voltage should allow for a lower VCORE to get total stability, as opposed to leaving the VTT at its stock setting. And the Conroe C2D's were more tolerant of VTT settings at or above 1.4 (although I don't think you need to set it that high. Just for a viable and safe overclock, you shouldn't have to set it at all for 3.0 Ghz)
With the right aftermarket CPU cooler -- a heatpipe cooler -- you should have perfectly safe load temperatures with the properly-set "totally stable" voltage, and there should be no risk of damage by either heat or voltage.
. . . . Unless, of course, you have an absolutely s***ty CPU as shipped from INtel. Or you'd done some damage to it before.
ekoostik
202
Ok I just built a new (first) rig and have been looking for advice on how to stress test the system. I stumbled in here on accident and found lots of good advice on what to use to do the stress test. Seems like the preferred methods are: Prime95, Orthos, OCCT, Intel Burn Test, and MemTest.
Any others that I've missed?
Also, could somebody point me to good sources on how to do this type of testing? Where's the best place to get the software? What are the best settings for each package to use? I know there's a wealth of information out there about these but I've been struggling to find a good consolidated or trustworthy source.
Thanks for any help!
VirtualLarry
56,587
10,227
Which is complete BS. Unfortunately, both ATI and NV cards have sub-standard engineering margin, especially as far as temps and power go, so they attempt to prevent what is otherwise perfectly-normal software from running on their GPUs.
Imagine if Intel throttled their CPUs down, if someone ran a NOP-loop or something. (Ok, ok, for the technical folks, I know that wouldn't comprise a stressful load, but just imagine for a minute that it did). People would be getting their pitchforks ready.
The point of a lengthy test is, the longer you run it, the longer your confidence interval is. One other reason for a 24hr test is that it subjects the test system to both thermal and AC cycles during the day and night, subjecting it to all possible variances.
Yes, I personally test for 24 hours, but as I noted in my thread (which I could probably dredge up), it wasn't good enough. My rig was rebooting, mysteriously, after several weeks at a time. I have since reduced the overclock on that machine from 3.2/400x8 to 2.8/350x8, and now it runs continuously without issue.
aigomorla
21,126
3,653
http://forums.anandtech.com/me...=2339756&enterthread=y
^ that is why...
Always test your machine.
I dont care if all you do is game, and interweb.
The last thing u would want is to fubar a voltage setting, and have windows get corrupted later on only to have to go though the mess of reinstalling it.
Munky
9,372
I disagree. The Furmark gpu stress test creates an unrealistic load on the gpu, with the sole intent of stressing it as much as possible; the kind of load that would never be encountered in actual games. If my video card runs every game out there without overheating, then I don't care if it can't run some synthetic stress test. CPU's are more general-purpose than gpu's, so they need to handle just about any code a developer can write. But even so, if there was an overheating issue in some stress test that would never be replicated in actual apps, I wouldn't care much about it either.
VirtualLarry
56,587
10,227
I disagree, more and more, GPUs are being used for GPGPU usage, which means that they are used for processing much like a heavily-parallel CPU. That means, that they should be stable, no matter WHAT load the software places on them. You're wrong about Furmark and OCCT being "unrealistic". When processing GPGPU data, the GPU is placed under similar loads. So the bottom line is that AMD and NV don't design for the worst-case, loads, only average, and that is going to hurt them once GPGPU usage increases in the market, as those users are going to want a STABLE platform for processing. The sad fact is that not too many of those cards on the market today can handle that type of processing load 24/7.
Markfw
May 16, 2002
27,392
16,236
I have to disagree on the last point, at least with my qualified statement. I have 22 video cards running 100% 24/7 for over a year now. All are fine (and F@H wil see a bad card)
HOWEVER
I only got double width cards, virtually all are NOT overclocked (unless its factory OC) and all run fans@ a minimum of 55%. Its only reasonable with what I am doing with them.
MikeShunt
35
I think the stress tests prove if its a fully working OC or not. I have often wonderd myself though as at the end of the day stress test utilities are uually artificial and dont represent real world load.
Munky
9,372
And how are GPGPU apps more stressful than a high tech game like Crysis? Virtually all modern games involve complex shaders, with varying degrees of load on the gpu. People have been running F@H on gpu's for some time now, and I haven't heard anything about vendors throttling the gpu or the OCP kicking in when the app is running, as opposed to Furmark.
VirtualLarry
56,587
10,227
That's the key, varying degrees of load. Games don't put a huge 100% load on a GPU. Scenes have varying complexity. GPGPU apps are different. Just like Prime95 is a different app than Microsoft Word, and puts a lot more load on your CPU. (Don't forget, Prime95 is a working app too, not just a stress-test program.)
Did you know that a few months ago, after "optimization" of the F@H core code that runs on GPUs, people were complaining because their GPUs were getting too hot and erroring, due to the load, so the F@H people put in voluntary throttling, to allow the GPUs to run cooler. Face it, video cards as built today are not designed to run with 100% 24/7 load.
Btw, F@H has burned out at least one of my video cards, an Asus 9600GSO that was factory overclocked.
Munky
9,372
And if they were designed for 100% loads 24/7, they would most likely cost more. As a gamer, I sure as hell don't want to pay extra for a card because some other people are gonna be using it for F@H 24/7. Let them get their own gpgpu-approved version.
Markfw
May 16, 2002
27,392
16,236
Did anybody read my post above ? I have over 20 cards 24/7 and no problems or orverheating.... And most cost less than $200.
slash196
1,549
I gotta say, if you get a crash in the stress test but have never had a blue screen or artifact in three years, your stress test might have a bug that's crashing it. Within 40 seconds is a "massive memory error"-type problem, and you should see other evidence of that.
pctwo
397
ok, let me ask you guys this: what's the longest you've run prime for and have it fail just when you think you are in the clear?
from my experience, my OCs tend to fail quickly, in minutes or the first hour.
I would never feel comfortable using a system that fails prime in 40 secs, though :)
Rubycon
Madame President
Aug 10, 2005
17,768
485
Would you drive your car with the wheel lugnuts hand tight?
You're playing with fire here. Anything you do with your computer cannot be trusted. From corrupted pictures to media files that won't play back - the possibilities of this biting you HARD are limitless.
ChaosDivine
370
+1 Your CPU is not even guaranteed 100% problem free (could very well be 99.999999999%) even with Prime testing, let alone without.
JimmiG
2,024
112
I on the other hand do care about Furmark and other synthetic tests. Sure, they're artificial, and maybe unrealistic, but they do not do anything "forbidden". They don't silently overvolt the GPU or something. The video card is just executing standard instructions written according to the SDK's and API's out there. It should not fail doing that. If it does, the quality of the engineering is indeed questionable. They have taken shortcuts because they thought that no app or game would hit that close to 100% GPU usage.
Also, the exact same scenario Furmark creates might appear one day in some game or other application. For example, there's an addon for Oblivion that seems to use a similar technique to draw grass. That makes my 4850 cooling fan spin almost as fast as it does during the Furmark test. Maybe if I had a more poorly ventilated case, or lived somewhere with a hotter climate and no AC, the video card would have failed... Who's to say, when the video card does not pass basic stress testing?
