outlook problem
Smokey0066
using full version of outlook.. when i try to send an email.. i get 551 relay request denied... wasup with that?
if i use the test feature i'm able to send and recieve the test mail.. but if i try to send out to anyone but myself it flops...
thanks guys.
Zim Hosein
Super Moderator | Elite Member
65,297
403
Smokey0066, it could be on the ISP's end. Sometimes, when my e-mail server isn't working, I receive weird error messages, but the test e-mail works. :confused: Just a thought.
Paladine
17
It has to do with settings on the mail server. Relay allows you to send messages to users that do not have mail boxes on the server. Basicly its used to prevent spamming. If you try to send to yourself no relay is needed but if you send to anyone else the server will have to relay the message. Try looking at your Outlook settings to see if you have it set to authenticate when sending. Most mail servers that are administrated properly will force you to authentcate while sending or will only relay for certain ip addresses (usually ones that the assign when you connect). Hope this helps!
Smokey0066
hmm.. today without changing any settings i was able to send and recieve okay.. does that mean that it was likely a server problem?
Paladine
17
Most likely. If the administrator was playing around with settings on the server that have to do with mail relay then he could have mistakenly killed relay for people that have boxes on his server as well.
