I figured I would post this since I got the board off of Hellburner.
[Copied from another post on another forum]
I've been experiencing errors with this board ever since I installed 2 match processors in it, I'm running linux with it, and it will somtimes give me weird gibberish errors, and I have to reboot. But, whats weird is, it won't do this all the time, somtimes I reboot it and its fine till I reboot it again then it starts spittin erros at me again, but then it goes away after a reboot. I have a suspicion that I don't have the jumpers on the VRMs set right, if somone knows the jumper settings for these, it would be appreciated. I should also note that the processors are overclocked to 233, and they have brand new HSFs on them, so I don't think that would be the problem. Any ideas and suggestions are appreciated. Thanks
EDIT: Well its done it again on a install of Redhat 7.3. I can see some of the error, but most is blocked out by menus in the installer. Some text I think may be important is: "EIP is at (2.4.18-3BOOT)" and "Process kjournaled (pid 67, stackpage=c3e1f000)". Seems to do it every time now.
