OT: i could use some help immediately please!!!
I have a HD on another comp failing as we speak. Is there any way to move some files over my network in safe mode? I tried starting in "safe mode with network" but that didn't seem to work.
Safe mode itself didn't work either. Maybe i'm missing something?
Windows 98se on the failing HD.
Not a hude deal if i can't get the files, most are backed up. I just wanted to get the ones i could in case i missed some backups.
It keeps telling me it "now safe to turn off your computer" but i'm afraid it won't start again if i do.
sounds like the shutdown process was initiated on that computer. You may not have any choice but to reboot.
In cases like this, I usually pull the hard drive out and pop it in another PC as a secondary drive and try and pull the files off that way. If the HD hasn't completely died, it's usually successful, your mileage may vary. It's faster than over the network.
I had to reboot it this morning & when i did it automaticly ran scandisk before it ever rebooted. Finally restarted & have been trying to run scandisk all morning now but kept having problems completing it. Finding bad sectors. So it probably isn't completely dead.
Looks like i'm at the point now i probably will have to try rebooting(shut it down).
/crosses fingers
I think i may have lost it... can't get it to restart :brokenheart:
It was an old HD, out of my 1st computer... about 6 years old. RIP buddy
Maybe my nephew could take a look.
Looks like a HD recommendation thread now.
Maybe it's an omen to upgrade the whole thing... retire the XP1800 & all.
/tries to look on brightside
Before you give up the ghost, pull the HD out, and put it in another PC as a secondary drive. You might be able to recover the files you want then.
Originally posted by: Coquito
Does the freezer trick still work these days?
Sometimes yes, sometimes no. It didn't work for me when I was trying to pull data off of my wife's crashed hd. Others have had success with it however.... But then again, at that point, it doesn't really matter anyway, so it never hurts to try.
I'm you're going to try this make sure and put it in a good ziplock bag.
