Zaap
- Jun 12, 2008
- 7,162
- 424
- 126
Meh. The Dell Adamo is a unibody aluminum design. Sony, Samsung, Asus and possibly others also make very nice aluminum designs. (Not sure if unibody, though).http://en.wikipedia.org/wiki/MacBook#Aluminum_unibody_model
single piece light weight laptop frames maybe?
It's not that the other OEMs can't 'afford' to do this. If a buyer starting range is $1200-$1700 and up, then they can get very much the same build quality from a PC laptop.
Anyway, by components I thought we were talking about internal hardware that actually makes a real world difference to computing performance.
Apple has one of the best magic acts going; even tech-minded people that should know better are fooled by the slight of hand. But there's nothing magic going on under the hood of any Mac. They use the same third party components as anyone else, and then allow them to lapse even years behind the curve of the PC world. People forget, Apple was stuck with Core2 hardware for the longest time when the entire PC world had moved on. Currently they're playing catch-up with IvyBridge.
PC OEMs more often use discreet graphics from nVidia and AMD when Apple will fall back on (traditionally worse) onboard GPUs, or GPUs YEARS behind the current best such as with the MacPro.
By the way, this sort of thing is another slight of hand Apple's pulled off to spin a negative into a positive with all of their 'whole widget' lore. The myth is that using better third party components introduces driver issues and instability on the PC side AUTOMAGICALLY, therefore Apple's doing it better by using lesser hardware and fewer choices. The reality is, though some new hardware can introduce instability if the drivers aren't fully worked out, this is hardly a given, and in fact the exception not the rule. Most PC users would not give up newer faster GPUs, or modern audio hardware, for example, for some myth that older, slower (or worse yet, onboard) hardware is always 'more stable'. It's just a myth that Apple's exploited very well for insane profits.
With things like networking hardware, audio components, I/O controllers, Apple is either behind the curve or using the same lackluster components (Realtec, Atheros, Broadcom, Marvell, Intel, etc.) as the most budget of PC makers. Not that there are terrible components in most Apple computers, just nothing all that special and magical like they're made out to be. A quick glance at any Apple hardware troubleshooting forum will reveal users having problems with any of the above, the same as any other make of computer.
