Organ donor thread
Are you an organ donor?
  • Yes
  • No
lxskllr
60,413
10,804
You haven't or won't immunize your children? You don't/won't do standard screening for yourself or them?
You're awfully good at selective reading. I suggest to reread every post I made in this thread, and you'll have your answer.
TheVrolok
24,254
4,092
I read them and I think you're full of it. You said you're against modern medicine, but will use it anyway. Yet you pick a specific battle with organ donation claiming at first that you believe it halts evolution, and then change your argument to state that it causes overpopulation.
It sounds like you really don't have any legitimate reason and just want to be "against the system. "
lxskllr
60,413
10,804
I pick a specific battle with organ donation because I make a direct optional decision to participate or not. As far as the rest goes, it's because I'm hypocrite. The correct answer is to always forgo medical treatment, but the drive for self preservation overrides logic, and doing what's best for everyone.
I recognize my hypocrisy, do you recognize your illogical sentimentality?
TheVrolok
24,254
4,092
As long as you admit the hypocrisy, I have no problem with your argument. I'm not sure I see this "illogical sentimentality" to which you're referring.
13,870
Yes, but only when I die. I don't really care what they do with my body once I'm dead. If it can be used to let someone else live longer than go for it.
BoomerD
66,430
14,838
Nope. Not that I'll need them once I'm dead, but my parts aren't usable...nor can I donate blood.
DCal430
6,020
9
If you are donor watch out. If the hospital finds out that you are a donor and thinks someone will make better use of your organs than you currently are, they won't hesitate to let you die when they could save you.
TheVrolok
24,254
4,092
Fail? Trolll?
disappoint
10,132
382
Like an inmate for example?
KeithTalent
Administrator
Nov 30, 2005
50,231
118
Yep, they can do whatever they want with my corpse.
KT
Feb 6, 2007
16,432
Not yet, but that's solely from laziness. I imagine I'll check that box the next time the form comes around.
