DannyBoy
This is much more of a processor thread.....
....and i can see it turning into an AMD vs Intel thread....
Originally posted by: AtomicDude512
Anyone who knows speeds?
Originally posted by: Snoop
Winz, what if AMD doubled the cache, and 'borrowed' Hyperthreading, and called it the Athlon Quarterhorse, which ran 200 mhz slower than the barton, but dominated it in the majority of benchmarks. Would MHz then be an accurate guage of performance or would an arbitrary number increase be better?????If you knew the mhz of both the "240" and "242", you would be able to come to some sort of conclusion as to how much faster the "242" is...
Then that would be a different processor. He's talking about comparing CPU speeds of like processors. Your extreme example is Willamette VS HT Northwoods. The irony of this statement is that a lot of people who say Mhz is a myth, also refer to how poor the P4 performs (even nowadays) based on the first batch of willamette benchmarks.
I dont see why you shuldnt used Mhz. Higher end processors such as Sun, HP, Alpha, SGI, all use Mhz. None of the companies bothered to use a PR rating system. Centrino laptops @ 1.6Ghz match or beat 2.5Ghz P4's, but do you see intel with a PR system?
But they didn't. There are no architectural differences between the 240 and 242.Originally posted by: Snoop
Very true. But they do still use mhz as part of the equation.Originally posted by: jhu
those companies emphasize the spec benchmarks more than mhz.
Winz, what if AMD doubled the cache, and 'borrowed' Hyperthreading, and called it the Athlon Quarterhorse, which ran 200 mhz slower than the barton, but dominated it in the majority of benchmarks. Would MHz then be an accurate guage of performance or would an arbitrary number increase be better?????If you knew the mhz of both the "240" and "242", you would be able to come to some sort of conclusion as to how much faster the "242" is...Where did you find this out? I thought that they varied within the same group by frequency, HT bandwidth and/or cache size. Wouldn't that make them a different architecture much like the northwood and willamette are different architectures? I would figure that the 240 = old 400FSB 256K willamette and 242 = 533FSB 512K northwood. If my reasoning is flawed, that is a huge price gap for there to be no architecture differences between the chips.But they didn't. There are no architectural differences between the 240 and 242.
The Opteron 240 will run at 1.4GHz and cost around $340 in volume quantities, said sources, while the Opteron 242 and 244 will run at, respectively, 1.6GHz and 1.8GHz and cost around $800 and $900.
c|net news.com linkThe Opteron 240 will run at 1.4GHz and cost around $340 in volume quantities, said sources, while the Opteron 242 and 244 will run at, respectively, 1.6GHz and 1.8GHz and cost around $800 and $900.
Think so? I figured the 1.4ghz would be of the 256k flavor.Originally posted by: ElFenix
looks like they're all coming with 1 meg cache.
It could easily be argued that basing performance on MHz is equally as vague.Great. That's AMD for ya! An even more confusing sliding scale for performance based on an imaginary starting pointSimply look at how the P4 has evolved; with each new stepping, performance did not scale directly to MHz, so at least this scaling system will give values relative to its predecessors.
At least theirs is a "real" number and scale that has been used for many years and many companies. AMD's scale is self sufficent and only to their needs. It's not to help the customer but to help themselves look better. Plus having 3 different numbers scale for 1 chip is confusing. Pentium as P4 and P4 Mobile or Xeon. It doesnt have P4 100 p4 200 p4 300. Ontop of that it's then done by scale of performance (i.e. p4 140 p4 240 p4 340). It's much easier just to name the chips different than to have like 20 different number names that are confusing to the end customer.
I love AMD and their chips, but the names they pick and numbering isn't helpful.
So, you would have no idea how a P4-2.66ghz would compare to a P4-2.8ghz?Originally posted by: Snoop
In what way is MHz a good sense of reference? MHz mean nothing to the performance of a cpu.Duh, yeah of course you could always check the system specs. But it'd be like GM coming up with a new name for the V6. Of course there are V6 out there that outperform V8's and It doesn't really depend on what the "number" is after the v, but it gives the buyer a good sense of reference to the assumed power that the car can output. So if GM started calling their engines 140, 242, 340 and making the people LOOK for the actual displacement, how annoying and stupid would that be?
Using mhz as a point of reference between two completely different processes doesn't work so well, but using it amongst the same family is very relevant.
MUCH more relevant than adding a 2 to the model number.
