Opinion on Logitech X-530 5.1 speaker system?
for around $60 you can pick up logitech z3e's on newegg. much better sound quality than the 530's except there 2.1 vs 530's 5.1 config. id go with the z3e
Speakers are overated 🙂 get a headset some reasons why
1. you can listen to it as loud as you want
2. small
3. portable
4. very very easy to understand where someone is coming from left or right side improves you skills in games
5. cheap
Yeah, I've also got the X-530's and i picked em up on sale (which they happen to be quite often) for only $45 CDN!
They're great I think personally, and would NOT hesitiate to reccomend them again..
Not to mention Logitech's RMA's are one of the best in the business
im planning on picking some of them up after i heard them at a friend's house. good 5.1 system considering that they can be had for around $50... but then again im not too anal about my sound quality.
Originally posted by: kumarshah
My friend keeps telling me that Sound Quality won't be that good.
What to do...what to do...
go to a store and listen to them yourself. Problem solved.
I was just shopping for speakers myself and I must say that these "cheapo" 5.1s really don't sound better than a good 2.1 setup. The most impressive speakers that I've heard were the Logitech Z-2300s. If I only had that extra $50 to add to my budget...
The Logitechs Z-2300swere heads and shoulders above the rest of the speakers that they sold(circuitcity)
On the topic of soundcard, how do I check exactly which one do I have?
Do you know if you're using a soundcard or integrated sound?
If you know your motherboard, you should be able to look up the integrated sound it uses if that's what you're using.
Originally posted by: t3h l337 n3wb
I have the X-530's and I think they sound great. Then again, I'm not too picky on audio...
Same. I bought Logitech's 2.1 setup a couple years ago (don't remember the model #) for around $50 and I've been really happy with them.
It says in Sound and Audio:
SoundMax Integrated Digital Audio
Well, that's what you have then.
You could benefit from a soundcard, but a good one is going to cost you about as much as the speakers cost.
