Mem
I tried hardware acceleration and it did not work on 32 bit version of Opera(says it was enabled in Opera:config but only running 2FPS on test below )anyway tried 64 bit version and it works fine,btw you can try this test here to see if you get 60FPS with hardware acceleration enabled https://ie.microsoft.com/testdrive/Performance/ParticleAcceleration/ ,without you should get something like 2FPS.
Going to stick with 64 bit version now of Opera with hardware acceleration enabled 🙂 .
Btw bruceb tried that tool for moving my stuff from 32 bit to 64 bit Opera,works great 😎 .
Also type opera:gpu in address bar to see your hardware status of acceleration etc...
http://html5test.com/ I had 400 on test score with 64 bit version, 32 bit version was 385
http://my.opera.com/chooseopera/blog/2011/10/13/opera-12-alpha-with-hardware-acceleration also a couple under hardware acceleration section for you to try.
