I'm looking into upgrading to a 24" wide screen lcd for quite some time, but am constantly disappointed by claims of input lag and some motion blur. I would go for 2x 19" lcds since this would mostly be a monitor used for graphic/text design, but I also use my PC for movies and TV, so a 24" would be much nicer in that case.
For a while I was hooked on the 2405fpw, until I started to do some more in-depth research and realized what "input lag" actually meant, and it is definitely something that I don't want to deal with. I don't care if you hardly notice it, it's there, and it would bother me.
I want to know if there is a 24" LCD available with the following, I'm sure it would be crazy expensive, but it's something that I'm willing to save up for:
1) HDCP support
2) 8-bit color depth
3) minimal or preferrable no input lag
4) decent response time (sufficient for movies/tv, don't do too much gaming)
5) image quality good enough for graphic design
Does this monitor exist? Is it $5,000? More?
Has the 2407 finally dealt with the input lag issue? What about the fancy NEC monitor? Although it's only 20", it might be good enough if there is no input lag.
Otherwise, for my requirements, what 2x 19" monitors would you recommend?
1) HDCP support
