What a crazy question.....
OMG. I just ran CPUZ.....and two of my cores are gone!!!!
OMG Koala pr0n!
I have your cores... they're safe... for now, give me a 512GB SSD and a GTX Titan or you will never see them again! :twisted:
reseat the cpu...
u may have a bad pin.. or a lose pin... or possibly the board could be bad too.
Go into bios and see if 4 cores is being detected inside bios.
If u do see 4 cores is in bios, then its windows itself not detecting the extra 2 cores.
OP do not use registry cleaners, they cause way more problems than they solve.
At a push only use a registry cleaner if you have a specific issue you think running one might solve.
Sources: My family and friends who screw their PCs up with registry cleaners then call me up moaning about how the "helpful" program broke something.
It would be enlightening to know what triggers this particular difficulty. I've gone up and down in the number of CPU cores many times on a single Windows 7 installation, and it has always (so far) properly autodetected them.
LOL, I think this happened to my wife's workstation the other day. I ran CCleaner on it the day before and the next day it showed the Black Screen at startup so I suspect that something got screwed up in the registry, maybe a critical file got deleted or altered. I wasn't about to spend all day trouble shooting it so I just did a fresh Win7 & MSFT Office install (all the data was on a HDD and unaffected). It's the last time I run that sucker (even though it has good reviews).OP do not use registry cleaners, they cause way more problems than they solve.
I've been using CCleaner for many years, with multiple PCs and it never caused any problem, also Windows creates restore points regularly, so I could probably use that, like I did when the official tool from AMD for removing drivers caused my OS not to work anymore.
The best way to keep your registry from getting borked is not to install a bunch of weird/free software. In the end it's usually better to nuke and pave than to mess with excessive registry editing or automated "cleaning." My last work machine lived for five years on one XP install, never once "cleaned" the registry. It was still fine when migrated to Win7 this year.
