OMG!!!! NEED SERIOUS COMPUTER HELP
thehype2049
37
oK, I GOT HOME today and i started my comp as usually, int he bottom taskbar, there was an icon from microsoft, i was downloading a update,,,,after i installed and rebotted, windows got messed up......liek the login screen comes and when i log in i get an error message...then nothing opens. i cant do anything,,,,not even 1 single thing.......i want to acrss system restore, buht he only thing which i can do it browse through firefox.......casue when u send ian error report, it opens up my firefox.....there is nothign i can do,...no icons....no satrt./.....safe mode does not work..............please hel me please.......
Gravity
5,685
Were you installing sp2 by chance?
Can you reinstall windows?
Can you boot into safemode? If so, go to control panel, add/remove proggys and remove sp2.
gamerj
169
reinstallin windows...ouch..could u maybe try to install windows "over" your current screwed up version?
Slick5150
8,760
It also appears to have screwed up your ability to spell or use any kind of sentence structure.
thehype2049
37
alright i got it working now again, you wont belive wut i had to do.....and no it wasnt sp2,, it was sumintg else....
i had to reboot in safe mode with command prompt, then i had to type in the following script to run system restore
%systemroot%\system32\restore\rstruie.exe
damm windows
Tarrant64
3,203
I didn't know you could do that from the cmd prompt. Thanks for helping yourself and teaching me a new thing.
thehype2049
37
LOL NO PROBLEM.....OUT OF THE PROBLEMS WHICH I HAVE ENCOUNTER, ID RATE THIS AS A MID-HIGH END PROBLEM........I MEAN, I COULDNT GET INTO ANYTHING ,,,NOTHING AT ALL
Tarrant64
3,203
Yeah, i've had similar problems before. I always end up having to do some weird what you would call mid-high end trick to get things going again. i've seen the dos screen too many times in my days of Win XP.
kornphlake
1,567
9
okay, so I've had mucho trouble installing "critical updates." I'm on dial-up and high speed isn't really economically available in the area so don't suggest that. I'll get half way through installing some update then the download will stop for some reason. If I reboot and connect to the internet again sometimes it will finish the download, or some times it will botch up to the point where when the update is installed it doesn't go through correctly because of a corrupt download. Is this common even for those on broadband connections? Is there some other way I can get the updates besides downloading them, I've spent literally days trying to download a single 2 mb update.
