OK, got the Airaid CAI installed today. Took me about an hour to do, as the instructions were very clear, with only one exception.
Had to remove the air box that came with my ram air hood though, as the filter was too big to fit in it. Not a big deal though, as the Airaid heat shield is awesome.
The Airaid filter is freaking massive, but thats to be expected as according to an Airaid rep I spoke to, it's one of the highest flowing filters they have.
Just to give you an idea of the size of it, here's a picture of it next to the Afe Pro S dry that I had on before:
And here's a pic of the air tube next to the K&N that I had:
As you can see, the Airaid is noticeably wider..
A pic of the final install:
After driving off for the first time, I noticed that the car felt a little less powerful than before. It was to be expected though, as it takes time for the PCM to adjust to the greater air flow from my previous set up so I was definitely running a little lean.
Reinstalling the Diablosport 93 CAI tune removed the performance loss completely (new baseline parameters), and the car now feels noticeably more powerful than it did before. Throttle is also more responsive, and the engine is revving higher....sounds better too
It will take a few days for the PCM to fully adjust and calibrate for the greater air flow though, so I expect the performance to keep increasing until it reaches the optimal level.. :thumbsup:
