OLED 3D googles
Sureshot324
3,370
Link
the equivalent of a 105-inch movie screen viewed at 12 feet
Now this is the future of gaming! Can't beat almost having your entire field of vision in the game.
OLEDs are perfect for this since they emit a low amount of radiation (i wouldn't want a pair of lcds half an inch from my eyes). One potential problem though is resolution. How many pixels can they pack into a 0.59" screen? Still, the technolagy can only improve, and I really hope this catches on.
Crescent13
4,793
Couple that with an x-fi, and the shure e5c $500 headphones, and you will truly be in the game.
(16x AA & 16x AF from 2 7800GTX's couldn't hurt either)
Mar 19, 2003
18,289
Originally posted by: Sureshot324
Link
That would be the important question for me. (Well, if I were ever to be interested in 3D goggles anyway, and I'm not sure that the idea appeals to me in practice necessarily)
But it does sound like a cool idea...hopefully larger OLED's are closer to becoming mainstream (although I feel like we've been saying that for quite a while now)
Crescent13
4,793
One thing that I noticed in the FAQ's, it ISN'T a stereoscopic display. Man that would be cool if it was.
AnitaPeterson
6,050
637
Somehow that site doesn't seem trustworthy to me... the icons on the bottom aren't clickable, and they've mispelled "commercial"
Sureshot324
3,370
True, but if 3D googles catch on, i'm sure that stereoscopic ones would come out. Problem with stereoscopic displays is the video card has to do double the work, since everything has to be rendered from two different angles.
Edit: It is stereoscopic. See the blurb on the right.
Crescent13
4,793
Originally posted by: virtualgames0
105" screen @ 800x600 = crap..
With a lot of AA it could look decent...
16x Transparency supersampling AA from 2 7800GTX's should do the trick.
EDIT: you also have to rember, it said it was 800x3x600 pixels.
Rock Hydra
6,466
Pretty sweet. I'm thinking thought quite possibly eye strain might be a factor here. Yes?
Unkno
1,659
possible, but i'll bet by the time this technology hits mainstream where at least 1/4 of the people have it at low costs, the eye strain problem would most likely already be solved
flexy
8,464
155
For 3D operation, you will need to ensure that you are using a compatible NVIDIA graphics card and have downloaded and installed the necessary drivers from NVIDIA's website.
too bad i have ATI :)
flexy
8,464
155
it is...read further...but obviously needs nvidia cards/drivers
Looney
21,938
How would it be solved? Your eyes are still focused on a FIXED point a couple of inches away from your eyes.
Anyways, maybe if it had 720p or 1080p.
gunblade
1,470
Well, Ati doesn't have stereoscopic drivers for their graphic card. I always feel that Ati only has quality driver on the mainstream stuff, but not on anything else like linux, stereoscopic display, OpenGL, HDTV LCD scaling etc.
Crescent13
4,793
yup. you're right.
