SparkyJJO
- May 16, 2002
- 13,357
- 7
- 81
Unless you're bleeding your brakes, there should never be a reason to need brake fluid. As the brakes wear, the excess fluid in the reservoir will gradually go down. When you replace the brakes, the fluid will go back to the maximum amount.
I never push the fluid back in the system when replacing pads. Pushing cruddy heat cycled fluid from the caliper backwards into the lines isn't the greatest thing to do. I prefer to open the bleeder when pushing the caliper pistons back so as to keep from doing that.
This also means I need to top off the reservoir.
But anyway, using a 20 year old can of brake fluid is a bad idea. If it was a year old and was tightly sealed I'd see no issue, but 20 years? That's too long for any fluid.
