imported_Swami
Originally posted by: Markfw900
Also, it doesn;t matter which is hot and which is ground for the power-on switch, it works my momentarily closing the two pins together to enable a relay in the power supply. The problem is, if you short one of those two connects to the wrong other pin, bad things happen. If you are sure they are on the right two, then you could still have a stuck switch (allways on) and then it will never boot. I have seen that once.
ya, im positive its the right 2 pins, and am pretty sure none of the others shorted as i havn't touched them while the mobo had power. Any other way to short them?
