ZV, I checked the owners manual too for my '95 850T and in my chart, the arrow in that diagram stops at 68F (highly doubt its accuracy) but if you check the link I provided earlier, and info found elsewhere, the difference between 5w30 and 10w30 is better flow at colder temps only.
Volvo changed their ideas on oil weight and it was either in the late 80s or early 90s.
I remember being at a Volvo technical training class back then and the instructor told us that Volvo did a lot of oil testing and decided that 5w30 was best and should be used year round. He got that info from Volvo's own engineers in Sweden, didn't just pull it out of his ass. Volvo dealers (and others too) eventually changed the bulk oil from what was 10w30 to 5w30 back then too, not because dealer parts people or management wanted to but because that's what Volvo wanted dealers to use in their engines.
I've NEVER once seen or heard of any engine failing prematurely due to the use of 5w30 oil, not with Volvo, not with Toyota. Many other manufactures have also been using 5w30 for ages now, again, no problems. That's everywhere in the world, year round. Weights like 10w30, 15w40, 20w50 is pretty "old school" now. We're not talking about Vintage air cooled Porsche engines.
My 850 now has 216K miles on it and has probably had 5w30 in it for years before I bought it (6 yrs ago). No noise, no consumption in 5K intervals (Mobil 1 5w30).
Most cars in the US have been getting 5w30 for years. On Toyota's oil fill caps (since at least the early 90s), it says to use 5w30. If 5w30's temp range was a problem, don't you think that'd show up in all those engines by now?
In car dealerships, I haven't seen 10w30 oil in stock for ages. It's always 5w30 for most, and for newer engines, 5w20 or synthetic 0w20 depending on what the fill cap says. Engines that now use the 0w20 go 10K miles on oil changes.
Again, since people just aren't getting it: The problem is NOT THE OIL ITSELF. The problem is using an oil that the engine was not designed for.
I used my 951 (a
liquid-cooled engine) as an example earlier because the manual calls for 20w50 oil. That's what the engine is designed for. That's what the passages are sized for. That's what the oil-cooler is sized for. You don't go switching to lighter oil because the engine is designed to use heavier oil and lighter weight won't hold up as well and will thin out too much to maintain pressure at hot idle.
Also, Volvo clearly didn't "change their ideas about oil weight" in the "late 80s or early 90s" since the image I gave you was from the owner's manual for a 199
8 car. So it's
newer than the information you're claiming, yet it clearly recommends 10w30 over 5w30. Not only that, but, taken directly from the owner's manual for a
2007 Volvo S80:
When temperatures exceed 86° F (30° C) in your area, Volvo recommends, for the protection of your engine, that you use a heavier weight oil, such as such as SAE 5W-40 or 0W-40.
What Volvo
did change in the early 1990s was their engines. The old red block 4-cylinder was being phased out and the new modular 4/5/6 cylinder engines were coming into play. The more modern engines were designed for use with different oils than the old B-series fours and the boat-anchor PRV V6.
Also, you're simply wrong about there being no difference between the hot flow for 5w30 vs 10w30. A 5w30 oil has to have more viscosity modifiers and its going to end up as a thicker 5 weight oil at cold temps and a thinner 30 weight oil at higher temps than an alternative with a narrower viscosity spread. That's just the chemistry behind how multi-weight oils work. For each viscosity spec, there is a range within which an oil must perform, and some "30 weight" oils are thicker or thinner than other "30 weight" oils. A wider viscosity range means that an oil has a more difficult time meeting the specifications for either of the two ratings and generally a multi-weight oil will fall on the thicker end of the lower spec and the thinner end of the higher spec. (This does, of course, assume that all else is equal. Note that 0w30 oils are generally recommended to higher temperatures than 5w30 oils because 0w30 is, currently, only in synthetics and the superior thermal properties of synthetic oil are enough to overcome the issues associated with a wider viscosity spread.)
Of course, as I've already mentioned, there's not some magical tipping point at a specific ambient temperature; there's simply a gradual reduction in the ability of the oil to stay thick enough for the oil pump to maintain adequate pressure as ambient temperature increases. In the case of my '98 S70, the engineers clearly felt that 5w30 was not good enough for sustained loads at ambient temperatures greatly exceeding 86 degrees Fahrenheit. Is there likely to be any problem ever from a single person driving across flat roads on a 90-degree day with 5w30? No, of course not. But put 5 people in the car on a 95 degree day and push it hard going up Mt. Rainier and you're going to see at least some accelerated engine wear. Maybe not enough to show up for a while, but it'll be there.
You're right that, in general, engines don't "fail" (at least not completely) from using oil that is only slightly off from the recommendation, though I've seen issues with ring wear from people failing to change their oil or from prolonged use of much thinner than recommended oil. Still, most cars will have their electronics fail long before the mechanical bits of the engine really let go. That said, I will still always prefer proper maintenance over something that is merely "good enough." I tend to keep my things for a very long time.
ZV
