Oil Overfill on VW
kitatech
484
With some engines, 1/2qt over oil level is fine...likely most engines... ...also a 1200 pixel wide image is sufficient for posting photos on forums....wider images like this force horizontal scrolling or reduction of web sizing...
tamm
439
It seems the car is filled by a half a quart. Worst case scenario you aerate your oil, turning it into a froathy end for your engine. Or nothing happens at all.
Look alot of oil changes DIY or Lube result in overfilling, if it really bothers u, drain some oil out (use a small tube insert it thru the dipstick and pull out). If not keep on driving. Im not responsible for your engine tho.
silicon
886
I waited around 30 minutes after shutting off the engine to check the level. The dipstick seems to be pretty consistent when I use it. Every time I get an oil change, except for this time, it's at the max level inside the indented part of the stick. And whenever I check it between oil changes it's at that same level.
I suppose this could just be 5 quarts of oil in an engine that takes 4.6 quarts. But it's also possible that they put 6 quarts in.
Its assumed that that the car is level when the oil is checked? There was a way to remove oil by using a "oil sucker" that was inserted via the dipstick tube. You might try and get one of those and find another garage that does not overfill motor oil.
Squeetard
815
7
In a spec series having 4-5% cylinder leakdown instead of 2-3% can cause the same thing (dropping several places in the pack). No one on the street would give a shit though.
More to the point - on the race track there is MUCH more opportunity for the oil to be sloshed around, what with all the serious cornering, accelerating, and braking. On the street oil sloshing just doesn't happen (save emergency situations) so it's not a concern.
If the crank was actually whipping through the oil in this situation OP would likely have detected issues already, likely including frothy oil on the dipstick.
It is not about the crank sloshing through the oil in the pan. When an engine is running at higher rpm a lot of oil is elsewhere than the pan anyways. Windage is the massive air turbulence caused by the movement of the pistons up and down that throws oil around the crankcase. The new ls7 is a dry sump system, still GM engineers developed windage holes in the webs supporting the main bearings to combat this.
Dec 30, 2004
12,553
I routinely overfill by a half quart (5q vs 4.5).
That's like an extra 1/8 in the oil pan. Not something to worry about
JCH13
4,981
66
I understand that windage and sloshing are two different phenomena. I was referring to your comment about crank scrapers.
My point still stands though - yes, it can make a difference in racing, but no one on the street is going to notice or care about windage or crank scraping.
Squeetard
815
7
Whelp, robbing your engine of 8hp on a 200hp engine will kill your fuel economy by around 5%. That can add up. Whether you care about it or not.
Meghan54
11,684
5,225
BS. Half a quart overfill will not do that crap. And no matter how many times you repeat such nonsense doesn't make it true.
Just as an FYI, when the engine's running, the oil pan is much less than completely full.....so seriously doubt the oil, even at 1/2 quart overfilled, makes one bit of difference in gas mileage or hp creation.
If you have verifiable dyno results, please share them. Otherwise, I'm putting this down to BS with BS figures pulled out your rectum.
