Oil Dispenser Ideas for Cooking
Imp
18,828
184
Slowly getting into cooking on the stove, want to avoid non-stick so I need to oil ma foods.
I mainly use canola/corn oil and not olive oil. That means they usually come in plastic bottles with big openings instead of glass bottles with a "drip-free" or easy-pour opening.
What do you use for oiling a pan or anything when cooking?
I've found steel oil cans, cheapo glass bottles with inserts, inserts sold separately, and even ketchup/mustard squeeze bottles. Oil can sounds the best but I can't find them for sale locally. Thinking of using an old wine bottle. Need more ideas.
33,648
Just keep a dish of bacon fat in the fridge and grab a spoonful as needed.
Crono
23,720
1,502
I use a Misto if I want a fine spray, or a glass oil dispenser (a cruet) for drizzling.
Otherwise I just have the jug or can nearby for larger amounts. I use a lot of canola oil and olive oil.
Carson Dyle
8,173
524
I've always wondered how well that works, compared to your typical can of cooking oil spray. Pretty much the same? I use a little cooking spray almost daily, but a small can will last me for months. So I wouldn't bother just to save a couple of bucks.
Imp
18,828
184
Lot of squeeze bottle lovers here. Thinking of using an old stainless steel bottle. Should be easy to refill. Could be a bitch to pour though. Could get a different bottle cap...
Sep 12, 2004
16,852
59
86
If you go to Costco try some Ottavio avocado oil.
It's nice for making salad dressings and mayo, and it's a great substitute for olive oil because of its freakishly high smoke point (460F). Also, the bottle comes with a slow-pour spout built in; which can be both a good thing as well as irksome.
zinfamous
111,834
31,307
butter or grapeseed oil.
grapeseed is expensive, though...but it's awesome.
CraKaJaX
11,905
148
101
I bought a few glass bottles /w spouts (the kind you find on all the liquor bottles at a bar) at TJ Maxx a few years ago. Couple bucks each and looks nicer than plastic sitting on the counter IMO. Put some labels on them if you have different kinds of oils - I only have canola and olive.
twinrider1
4,096
64
Re: glass bottles with spouts.
But aren't those spouts open to the air? I have one, but I quit using it because I didn't use it every day and I was concerned about it going bad.
SunnyD
Belgian Waffler
Jan 2, 2001
32,675
www.neftastic.com
This.
CraKaJaX
11,905
148
101
They are. Personally, I've never had a problem with oil going bad. At least I'm still alive...? :confused:
lxskllr
59,888
10,387
I use a stoneware bottle with a cork in the top. It's made for table use with salad, but I don't think I'm breaking any laws.
