Originally posted by: Pepsi90919
can you count?I'm running a 1990 Civic Si (10 years old this year)
no
Cheers,
Aquaman
This is an old myth that began as a bit of truth. First, everything you know about oil is wrong.Synthetic is only for new cars, or for cars that have ALWAYS been using synthetic. If you use regular oil just once, don't switch back to synthetic.
anybody ever used XR-4 oil? they sell it here at the Napa stores, supposedly it's made by petro-canada and the newest stuff is SL-rated.
Well, in fact, "dino juice" is used overwhelmingly in mission critical applications like aviation piston engines, including rotary and turbocharged applications, where synthetic is the standard only for turbines due to the temperature and rotational extremes (10,000RPM is considered "idling" speed).In mission critical applications, like jet airplane engines, do you think they use regular dino juice? Absolutely not..
Originally posted by: BUTCH1
"In mission critical applications, like jet airplane engines, do you think they use regular dino juice? Absolutely not.. "
Since auto's dont have GE turbofans that spin at increidable speeds or have to operate at 35,000 ft
this grade of lubrication would be overkill..It cost me 8 BUCKS to change oil/filter at home every 2-3
months and I KNOW all the by-products are GONE!!
Originally posted by: Pacfanweb
" When you think about it, what you're saying doesen't even make any sense. Since Synthetic oil flows better at cold temperatures, how could the knocking be caused from poor oil pressure/circulation? "
Because and older engine NEEDS the oil to be a bit thicker in the morning to take up the extra few thousandths of clearance that may be in there from wear.....which is there because the oil wasn't changed properly to begin with.
The synthetic most definitely could cause the engine to knock under those conditions, because it flows easier.
I put synthetic in both my Tahoes around 55k miles, even though I don't believe in it totally, because I thought it couldn't hurt anything, and it wasn't that much more expensive.(on sale)
I was wrong.
Both engines started tapping on cold starts, and got worse as the miles increased. They went from tapping until the oil pressure came up, to tapping until you backed out of the driveway, to tapping half the way to work. (lifter tap)
I couldn't believe that both engines magically started doing this at the same time.
I didn't even have 3k miles on either oil change.
I flushed both engines to get all the synthetic out, changed the oil with regular oil, and the tapping stopped. Both engines now have normal oil pressure. With the synthetic, the oil pressure reading was lower.
You can quote me all the ball bearing wear figures you want, but those bearings do not reside in internal combustion engines, and therefore the tests are not representative of what you can expect in the real world (no surprise there, tests on anything hardly ever are).......as with anything, YOUR MILEAGE MAY VARY.
BTW, I have over 25 years experience in the automotive field, a degree in automotive repair from community college, and countless Ford and ASE certifications.
I have seen these results too many times to say that synthetic is OK to use across the board. It is not.
Yeah, I'm sure. I don't know what your search revealed, but check out the product lines of the major aviation fuel and lubrication companies like Shell, Texaco, Exxon, Mobil, etc. These major brands are the most widely used products in the industry.Are you sure? I've certainly never heard this. Synthetic oils were first designed with mission critical engines in mind. A quick search for "aviation piston oil" does indeed reveal some purely mineral based oils, but most all of them are at least semi-synthetic. They also appear to be higher quality than normal engine oil, so that may be.
Most of their piston aircraft engine lubricants are straight petroleum/mineral based single-weight or ashless dispersant oils. They certainly have mineral/synthetic blends, but these are still primarily petroleum base stocks blended with synthetic modifiers and additive packages.
Its not that they're necessarily 'higher quality' than a quality automotive oil such as Penzoil or Valvoline, its that they're blended and formulated for different needs and conditions.
BTW, I'm a former Amsoil dealer who did a lot of research and concluded that today's conventional oils are SO GOOD that I could no longer justify to myself the "synthetic" sales pitch, so how could I justify it to others? I let my Amsoil dealer license lapse.
Originally posted by: PeeluckyDuckee
For a new car, when is the right time to put in synthetic oil? We've changed the first oil at 1500KM already, yes too soon but I wanted it done. Do I have to wait for break-in period to be out of the way (10,000KM ??) before we do the change?
Please recommend.
Please recommend.
Originally posted by: bcmind
do not switch to synthetic oil.
civic does not need that kind of oil. it's a waste of $.
Originally posted by: cipher00
I switched after my 1st oil change, which was at 7500 miles. Here is a good article that says anytime after 6000 miles is good.
Hmm, now I'm really confused.
This article states that you shouldn't (!) use syntetics in a turbocharged engine. My Audi mechanic said it was fine (I have a 2001 S4)...precisely for the heat issues from the twin turbos. So now what? And what interval should we be changing?![]()
You absolutely should use synthetic oil in turbocharged engines! If anything, its those kind of high-heat, high-load applications that need synthetic oil.
Oh, ok, that's what I thought...
My mechanic puts in Castrol or Mobil-1. Are you suggesting that these need more frequent changes (like 3,000) rather than AMSOIL? (I could ask my mechanic to switch, or take AMSOIL in if I can figure out what grade I need...)
BTW, great post.![]()
Originally posted by: lsman
for those who want something to read about
oil change DIY
and read about the
story behind 5W-20 and 5W-30 switch (For newer Ford and 2001/02 Honda owner)
more direct link to the issue
