Originally posted by: bobdole369
I use K&N filters and would have sued the service center and the tech personally for destroying my equipment. Usually that gets your K&N back with an apology and the cost of service.
Originally posted by: Beau
K&N can suck my nuts. Put one in and the oil on the material ruined my MAF sensor. $500 part.
Anyway, use the OEM filters... get it from your dealer: This is why: http://www.pictars.com/users/Beau/fram.jpg
Oil: Mobile 1, RP, Redline (if you like to waste money to feel neat).
I thought it's fairly common knowledge that aftermarket Oiled Air Filters could damage your MAF. Doesn't matter if it's K&N or another company. If I was staying stock I would use OEM filters anyways.
our torque converter does not lock up until the tranny fluid is warm. When it does, your RPM will drop.
Take your K&N filter and hold it up to a light, see all those holes? That's where the dirt goes through. K&N allows more air through because it doesn't filter as well, and that extra air isn't going to do you any good at all until you're at WOT. Everyone uses K&N because everyone uses K&N, there is no other compelling reason to use one, unless of course your goal is to allow more dirt into your engine, then K&N is the way to go.
I don't agree with the first part - as I don't have a ton of holes on my K&N - its oiled - so there is really not a lot of places for any dust to get through. It gets hung up in the filter material.
I agree with the next sentence and the first part of the last. The biggest compelling reason to use one (and why I have one installed) - is to avoid changing the filter and paying $2.99 to some parts store every couple months.
Originally posted by: shortylickens
I used an expensive K&N filter and fancy synthetic oil for a long time in my pickup. Didnt seem to be anything special.
Recently changed back to cheap filters and oil. Car is running fine. I suspect I will keep using the cheap stuff and just replace it more frequently. Probably at the 5000 mile mark instead of 10,000.
