Oh drat!
I Saw OJ
4,923
Heres what you do;
1. Go to autozone and rent a code reader
2. Read and reset the code
3. Return code reader to autozone and get your deposite back
4. Take car to shop or buy the parts and fix it yourself.
With an OBDII car, the codes will pretty much tell you exactly whats wrong.
DaWhim
12,985
my scan gauge 2 can read code and reset code. good thing is I don't need to use it yet.
Nyati13
785
Originally posted by: Bateluer
Originally posted by: trmiv
Is the gas cap on tight?
edit: compuwiz1 beat me by a second.
What kind of idiot do you take me for?
*Runs to check*
Edit - Its on tight. :p
It might have a torn gasket on the gas cap. That failed my old escort during an inspection. Stupid gas cap... :p
iamwiz82
30,772
13
On most modern cars, a solid CEL means that there is an issue, but it is not serious. A flashing CEL means that there is a major problem and to seek service ASAP.
funboy6942
15,368
418
Remove gas cap, put gas cap back on. Open hood, remove pos battery cable for 5 minutes, put cable back on, drive car as normal and wait and see if light comes back on. If it does you got a problem, if not problem solved.
That will be $10 paypal please for online diag to my paypal account, thankyou, come again.
amddude
1,711
*Runs to check*
If that was the problem, it will take several times of starting and turning off the car for the light to go out. I have a 04 corolla
jlbenedict
Banned
Jul 10, 2005
3,724
*Runs to check*
Thats why you do what Funboy42 posted above you. Disconnect the battery for five minutes.
origami
180
Bring it in to Midas for an inspection? I think it's free until you agree to get something fixed...I think.
