OGR problem
Are you running the latest client? If not then they probably don't count.
Also, it takes a day or so before your stats show up if you flush directly to dnet.
Yeah I'm running the latest client I upgraded to the lateest client to do OGR...I have submitted some blocks all ready. I have never seen it take more than a day for my blocks to show up in my stats.
skull, Just to double check, by latest client you do mean 463b?
Also have you checked your DNETC.ini file to make sure that it still has your userid correct? According to your log, how many stubs have you done?
Thw whole version # is v2.8010-463-CTR-00071214 I checked it has my user id right. How do you check your log?
skull,
In order to check your log, you first must have enabled logging when you set up the client.
In the setup, this may be found under #4) Logging Options.
I typically just set up a fifo log, give it a name like (machine_name.log) and leave the size to the default of 0 (this will create a 100K continuously updating log... usually good for a few days worth of info)
Configured in the dnetc.ini file, the lines would look something like this:
[logging]
log-file-type=fifo
log-file-limit=100
log-file=eliza_p.log
Unfortunately, if you never configured the logging, then you have no log to check. 🙁 If that's the case, then I'd set it up right away. I use a fifo log on every machine in my herd. 🙂
-Brian
I haven't tried the FIFO log option.
I have this in my INI file (I heartily recommend enablin Checkpoint files and Log files for all installations)
[logging]
log-file-type=rotate
log-file-limit=monthly
log-file=JonB
This style log file can get long, but its just hard drive space, right? 😉
I just put the logging thing in my ini file. Ill leave it run while im at work and get back with you guys. thanks.
Heres my log. My computer locked up some time while I wa gone.
dnetc v2.8010-463-CTR-00071214 for Win32 (Windows 4.10).
Using email address (distributed.net ID) 'jrw64@yahoo.com'
[Jul 21 18:31:03 UTC] The keyserver says: "i absolutely love her when she
smiles (dbaker)"
[Jul 21 18:31:06 UTC] Retrieved 24 OGR packets (24 work units) from server
[Jul 21 18:31:06 UTC] Loaded OGR stub 24/16-18-21-1-6
[Jul 21 18:31:06 UTC] Summary: 1 OGR packet (28.26 Gnodes)
0.01:21:58.30 - [5.74 Mnodes/s]
[Jul 21 18:31:06 UTC] 23 OGR packets (23 work units) remain in (memory-in)
[Jul 21 18:31:06 UTC] 0 OGR packets (0 work units) are in (memory-out)
[Jul 21 18:31:06 UTC] 1 cruncher has been started.
[Jul 21 18:33:50 UTC] *Break* Restarting...
[Jul 21 18:33:51 UTC] Saved OGR stub 24/16-18-21-1-6 (8.50% done)
[Jul 21 18:33:51 UTC] Summary: 1 OGR packet (28.26 Gnodes)
[Jul 21 18:33:51 UTC] 24 OGR packets (24 work units) are in (memory-in)
[Jul 21 18:33:51 UTC] 0 OGR packets (0 work units) are in (memory-out)
[Jul 21 18:33:53 UTC] The keyserver says: "PetPetPetPet! (cdy)"
[Jul 21 18:33:57 UTC] Retrieved 24 OGR packets (24 work units) from server
[Jul 21 18:33:57 UTC] Loaded OGR stub 24/35-1-8-4-11
[Jul 21 18:33:57 UTC] Summary: 1 OGR packet (28.26 Gnodes)
[Jul 21 18:33:57 UTC] 23 OGR packets (23 work units) remain in (memory-in)
[Jul 21 18:33:57 UTC] 0 OGR packets (0 work units) are in (memory-out)
[Jul 21 18:33:57 UTC] 1 cruncher has been started.
[Jul 21 18:39:23 UTC] Completed OGR stub 24/35-1-8-4-11 (1,936,984,283 nodes)
0.00:05:25.13 - [5,957,476.99 nodes/sec]
[Jul 21 18:39:23 UTC] Loaded OGR stub 24/35-1-8-4-10
[Jul 21 18:39:23 UTC] Summary: 2 OGR packets (30.19 Gnodes)
0.01:27:23.44 - [5.75 Mnodes/s]
[Jul 21 18:39:23 UTC] 22 OGR packets (22 work units) remain in (memory-in)
[Jul 21 18:39:23 UTC] 1 OGR packet (1 work unit) is in (memory-out)
[Jul 21 18:44:56 UTC] Completed OGR stub 24/35-1-8-4-10 (1,983,012,093 nodes)
0.00:05:32.60 - [5,961,991.68 nodes/sec]
[Jul 21 18:44:56 UTC] Loaded OGR stub 24/35-1-8-4-7
[Jul 21 18:44:56 UTC] Summary: 3 OGR packets (32.18 Gnodes)
0.01:32:56.04 - [5.77 Mnodes/s]
[Jul 21 18:44:56 UTC] 21 OGR packets (21 work units) remain in (memory-in)
[Jul 21 18:44:56 UTC] 2 OGR packets (2 work units) are in (memory-out)
[Jul 21 18:48:49 UTC] Completed OGR stub 24/35-1-8-4-7 (1,382,837,706 nodes)
0.00:03:52.52 - [5,947,177.47 nodes/sec]
[Jul 21 18:48:49 UTC] Loaded OGR stub 24/35-1-7-10-12
[Jul 21 18:48:49 UTC] Summary: 4 OGR packets (33.56 Gnodes)
0.01:36:48.56 - [5.77 Mnodes/s]
[Jul 21 18:48:49 UTC] 20 OGR packets (20 work units) remain in (memory-in)
[Jul 21 18:48:49 UTC] 3 OGR packets (3 work units) are in (memory-out)
[Jul 21 18:52:44 UTC] Completed OGR stub 24/35-1-7-10-12 (1,394,795,471 nodes)
0.00:03:54.70 - [5,942,886.54 nodes/sec]
[Jul 21 18:52:44 UTC] Loaded OGR stub 24/35-1-7-10-11
[Jul 21 18:52:44 UTC] Summary: 5 OGR packets (34.95 Gnodes)
0.01:40:43.26 - [5.78 Mnodes/s]
[Jul 21 18:52:44 UTC] 19 OGR packets (19 work units) remain in (memory-in)
[Jul 21 18:52:44 UTC] 4 OGR packets (4 work units) are in (memory-out)
[Jul 21 18:56:39 UTC] Completed OGR stub 24/35-1-7-10-11 (1,397,533,348 nodes)
0.00:03:54.68 - [5,954,957.93 nodes/sec]
[Jul 21 18:56:39 UTC] Loaded OGR stub 24/35-1-7-10-9
[Jul 21 18:56:39 UTC] Summary: 6 OGR packets (36.35 Gnodes)
0.01:44:37.95 - [5.79 Mnodes/s]
[Jul 21 18:56:39 UTC] 18 OGR packets (18 work units) remain in (memory-in)
[Jul 21 18:56:39 UTC] 5 OGR packets (5 work units) are in (memory-out)
[Jul 21 19:01:20 UTC] Completed OGR stub 24/35-1-7-10-9 (1,677,926,707 nodes)
0.00:04:40.67 - [5,978,204.98 nodes/sec]
[Jul 21 19:01:20 UTC] Loaded OGR stub 24/35-1-7-10-6
[Jul 21 19:01:20 UTC] Summary: 7 OGR packets (38.03 Gnodes)
0.01:49:18.62 - [5.79 Mnodes/s]
[Jul 21 19:01:20 UTC] 17 OGR packets (17 work units) remain in (memory-in)
[Jul 21 19:01:20 UTC] 6 OGR packets (6 work units) are in (memory-out)
[Jul 21 19:05:21 UTC] Completed OGR stub 24/35-1-7-10-6 (1,432,219,571 nodes)
0.00:04:00.67 - [5,950,869.52 nodes/sec]
[Jul 21 19:05:21 UTC] Loaded OGR stub 24/35-1-7-10-5
[Jul 21 19:05:21 UTC] Summary: 8 OGR packets (39.46 Gnodes)
0.01:53:19.30 - [5.80 Mnodes/s]
[Jul 21 19:05:21 UTC] 16 OGR packets (16 work units) remain in (memory-in)
[Jul 21 19:05:21 UTC] 7 OGR packets (7 work units) are in (memory-out)
[Jul 21 19:09:47 UTC] Completed OGR stub 24/35-1-7-10-5 (1,580,458,537 nodes)
0.00:04:25.37 - [5,955,679.00 nodes/sec]
[Jul 21 19:09:47 UTC] Loaded OGR stub 24/35-1-7-10-4
[Jul 21 19:09:47 UTC] Summary: 9 OGR packets (41.04 Gnodes)
0.01:57:44.67 - [5.81 Mnodes/s]
[Jul 21 19:09:47 UTC] 15 OGR packets (15 work units) remain in (memory-in)
[Jul 21 19:09:47 UTC] 8 OGR packets (8 work units) are in (memory-out)
[Jul 21 19:15:06 UTC] Completed OGR stub 24/35-1-7-10-4 (1,893,897,343 nodes)
0.00:05:17.31 - [5,968,602.76 nodes/sec]
[Jul 21 19:15:06 UTC] Loaded OGR stub 24/35-1-7-10-3
[Jul 21 19:15:06 UTC] Summary: 10 OGR packets (42.94 Gnodes)
0.02:03:01.98 - [5.81 Mnodes/s]
[Jul 21 19:15:06 UTC] 14 OGR packets (14 work units) remain in (memory-in)
[Jul 21 19:15:06 UTC] 9 OGR packets (9 work units) are in (memory-out)
[Jul 21 19:19:52 UTC] Completed OGR stub 24/35-1-7-10-3 (1,707,177,883 nodes)
0.00:04:46.05 - [5,968,026.60 nodes/sec]
[Jul 21 19:19:52 UTC] Loaded OGR stub 24/35-1-7-10-2
[Jul 21 19:19:52 UTC] Summary: 11 OGR packets (44.64 Gnodes)
0.02:07:48.03 - [5.82 Mnodes/s]
[Jul 21 19:19:52 UTC] 13 OGR packets (13 work units) remain in (memory-in)
[Jul 21 19:19:52 UTC] 10 OGR packets (10 work units) are in (memory-out)
[Jul 21 19:24:17 UTC] Completed OGR stub 24/35-1-7-10-2 (1,579,608,168 nodes)
0.00:04:24.89 - [5,963,058.25 nodes/sec]
[Jul 21 19:24:17 UTC] Loaded OGR stub 24/35-1-7-9-15
[Jul 21 19:24:17 UTC] Summary: 12 OGR packets (46.22 Gnodes)
0.02:12:12.93 - [5.82 Mnodes/s]
[Jul 21 19:24:17 UTC] 12 OGR packets (12 work units) remain in (memory-in)
[Jul 21 19:24:17 UTC] 11 OGR packets (11 work units) are in (memory-out)
[Jul 21 19:26:53 UTC] Completed OGR stub 24/35-1-7-9-15 (926,231,094 nodes)
0.00:02:35.36 - [5,961,492.27 nodes/sec]
[Jul 21 19:26:53 UTC] Loaded OGR stub 24/35-1-7-9-14
[Jul 21 19:26:53 UTC] Summary: 13 OGR packets (47.15 Gnodes)
0.02:14:48.30 - [5.82 Mnodes/s]
[Jul 21 19:26:53 UTC] 11 OGR packets (11 work units) remain in (memory-in)
[Jul 21 19:26:53 UTC] 12 OGR packets (12 work units) are in (memory-out)
[Jul 21 19:29:48 UTC] Completed OGR stub 24/35-1-7-9-14 (1,039,151,002 nodes)
0.00:02:54.46 - [5,956,078.16 nodes/sec]
[Jul 21 19:29:48 UTC] Loaded OGR stub 24/35-1-7-9-13
[Jul 21 19:29:48 UTC] Summary: 14 OGR packets (48.19 Gnodes)
0.02:17:42.77 - [5.83 Mnodes/s]
[Jul 21 19:29:48 UTC] 10 OGR packets (10 work units) remain in (memory-in)
[Jul 21 19:29:48 UTC] 13 OGR packets (13 work units) are in (memory-out)
[Jul 21 19:34:06 UTC] Completed OGR stub 24/35-1-7-9-13 (1,535,882,258 nodes)
0.00:04:17.46 - [5,965,309.44 nodes/sec]
[Jul 21 19:34:06 UTC] Loaded OGR stub 24/35-1-7-9-12
[Jul 21 19:34:06 UTC] Summary: 15 OGR packets (49.72 Gnodes)
0.02:22:00.24 - [5.83 Mnodes/s]
[Jul 21 19:34:06 UTC] 9 OGR packets (9 work units) remain in (memory-in)
[Jul 21 19:34:06 UTC] 14 OGR packets (14 work units) are in (memory-out)
[Jul 21 19:37:50 UTC] Completed OGR stub 24/35-1-7-9-12 (1,329,641,779 nodes)
0.00:03:43.91 - [5,938,180.63 nodes/sec]
[Jul 21 19:37:50 UTC] Loaded OGR stub 24/35-1-7-9-11
[Jul 21 19:37:50 UTC] Summary: 16 OGR packets (51.05 Gnodes)
0.02:25:44.15 - [5.83 Mnodes/s]
[Jul 21 19:37:50 UTC] 8 OGR packets (8 work units) remain in (memory-in)
[Jul 21 19:37:50 UTC] 15 OGR packets (15 work units) are in (memory-out)
[Jul 21 19:42:15 UTC] Completed OGR stub 24/35-1-7-9-11 (1,575,243,573 nodes)
0.00:04:24.33 - [5,959,269.76 nodes/sec]
[Jul 21 19:42:15 UTC] Loaded OGR stub 24/35-1-7-6-20
[Jul 21 19:42:15 UTC] Summary: 17 OGR packets (52.63 Gnodes)
0.02:30:08.49 - [5.84 Mnodes/s]
[Jul 21 19:42:15 UTC] 7 OGR packets (7 work units) remain in (memory-in)
[Jul 21 19:42:15 UTC] 16 OGR packets (16 work units) are in (memory-out)
[Jul 21 19:44:39 UTC] Completed OGR stub 24/35-1-7-6-20 (857,607,654 nodes)
0.00:02:23.47 - [5,977,234.67 nodes/sec]
[Jul 21 19:44:39 UTC] Loaded OGR stub 24/35-1-7-6-19
[Jul 21 19:44:39 UTC] Summary: 18 OGR packets (53.49 Gnodes)
0.02:32:31.96 - [5.84 Mnodes/s]
[Jul 21 19:44:39 UTC] 6 OGR packets (6 work units) remain in (memory-in)
[Jul 21 19:44:39 UTC] 17 OGR packets (17 work units) are in (memory-out)
[Jul 21 19:47:22 UTC] Completed OGR stub 24/35-1-7-6-19 (963,567,492 nodes)
0.00:02:41.68 - [5,959,572.32 nodes/sec]
[Jul 21 19:47:22 UTC] Loaded OGR stub 24/35-1-7-6-18
[Jul 21 19:47:22 UTC] Summary: 19 OGR packets (54.45 Gnodes)
0.02:35:13.65 - [5.84 Mnodes/s]
[Jul 21 19:47:22 UTC] 5 OGR packets (5 work units) remain in (memory-in)
[Jul 21 19:47:22 UTC] 18 OGR packets (18 work units) are in (memory-out)
[Jul 21 19:50:49 UTC] Completed OGR stub 24/35-1-7-6-18 (1,229,012,804 nodes)
0.00:03:26.70 - [5,945,877.13 nodes/sec]
[Jul 21 19:50:49 UTC] Loaded OGR stub 24/35-1-7-6-17
[Jul 21 19:50:49 UTC] Summary: 20 OGR packets (55.68 Gnodes)
0.02:38:40.35 - [5.84 Mnodes/s]
[Jul 21 19:50:49 UTC] 4 OGR packets (4 work units) remain in (memory-in)
[Jul 21 19:50:49 UTC] 19 OGR packets (19 work units) are in (memory-out)
[Jul 21 19:54:31 UTC] Completed OGR stub 24/35-1-7-6-17 (1,324,260,215 nodes)
0.00:03:41.97 - [5,965,700.42 nodes/sec]
[Jul 21 19:54:31 UTC] Loaded OGR stub 24/35-1-7-6-16
[Jul 21 19:54:31 UTC] Summary: 21 OGR packets (57.00 Gnodes)
0.02:42:22.33 - [5.85 Mnodes/s]
[Jul 21 19:54:31 UTC] 3 OGR packets (3 work units) remain in (memory-in)
[Jul 21 19:54:31 UTC] 20 OGR packets (20 work units) are in (memory-out)
[Jul 21 19:58:48 UTC] Completed OGR stub 24/35-1-7-6-16 (1,531,166,746 nodes)
0.00:04:16.59 - [5,967,157.88 nodes/sec]
[Jul 21 19:58:48 UTC] Loaded OGR stub 24/35-1-7-6-15
[Jul 21 19:58:48 UTC] Summary: 22 OGR packets (58.53 Gnodes)
0.02:46:38.93 - [5.85 Mnodes/s]
[Jul 21 19:58:48 UTC] 2 OGR packets (2 work units) remain in (memory-in)
[Jul 21 19:58:48 UTC] 21 OGR packets (21 work units) are in (memory-out)
[Jul 21 20:03:47 UTC] Completed OGR stub 24/35-1-7-6-15 (1,789,389,777 nodes)
0.00:04:59.02 - [5,984,100.86 nodes/sec]
[Jul 21 20:03:47 UTC] Loaded OGR stub 24/35-1-7-6-12
[Jul 21 20:03:47 UTC] Summary: 23 OGR packets (60.32 Gnodes)
0.02:51:37.95 - [5.85 Mnodes/s]
[Jul 21 20:03:47 UTC] 1 OGR packet (1 work unit) remains in (memory-in)
[Jul 21 20:03:47 UTC] 22 OGR packets (22 work units) are in (memory-out)
[Jul 21 20:08:20 UTC] Completed OGR stub 24/35-1-7-6-12 (1,622,932,056 nodes)
0.00:04:32.53 - [5,954,861.71 nodes/sec]
[Jul 21 20:08:20 UTC] Loaded OGR stub 24/35-1-7-6-11
[Jul 21 20:08:20 UTC] Summary: 24 OGR packets (61.95 Gnodes)
0.02:56:10.49 - [5.86 Mnodes/s]
[Jul 21 20:08:20 UTC] 0 OGR packets (0 work units) remain in (memory-in)
[Jul 21 20:08:20 UTC] 23 OGR packets (23 work units) are in (memory-out)
[Jul 21 20:08:22 UTC] The keyserver says: "it was boiling a run to the sea
(dbaker)"
[Jul 21 20:08:25 UTC] Retrieved 24 OGR packets (24 work units) from server
[Jul 21 20:08:28 UTC] Sent 23 OGR packets (23 work units) to server
[Jul 21 20:13:38 UTC] Completed OGR stub 24/35-1-7-6-11 (1,889,135,600 nodes)
0.00:05:17.39 - [5,952,020.51 nodes/sec]
[Jul 21 20:13:38 UTC] Loaded OGR stub 24/17-4-9-5-32
[Jul 21 20:13:38 UTC] Summary: 25 OGR packets (63.84 Gnodes)
0.03:01:27.88 - [5.86 Mnodes/s]
[Jul 21 20:13:38 UTC] 23 OGR packets (23 work units) remain in (memory-in)
[Jul 21 20:13:38 UTC] 1 OGR packet (1 work unit) is in (memory-out)
[Jul 21 20:39:23 UTC] Completed OGR stub 24/17-4-9-5-32 (9,369,673,606 nodes)
0.00:25:44.98 - [6,064,556.83 nodes/sec]
[Jul 21 20:39:23 UTC] Loaded OGR stub 24/17-4-8-38-2
[Jul 21 20:39:23 UTC] Summary: 26 OGR packets (73.21 Gnodes)
0.03:27:12.87 - [5.88 Mnodes/s]
[Jul 21 20:39:23 UTC] 22 OGR packets (22 work units) remain in (memory-in)
[Jul 21 20:39:23 UTC] 2 OGR packets (2 work units) are in (memory-out)
[Jul 21 20:46:20 UTC] Completed OGR stub 24/17-4-8-38-2 (2,515,577,801 nodes)
0.00:06:56.37 - [6,041,557.81 nodes/sec]
[Jul 21 20:46:20 UTC] Loaded OGR stub 24/17-4-8-38-1
[Jul 21 20:46:20 UTC] Summary: 27 OGR packets (75.72 Gnodes)
0.03:34:09.25 - [5.89 Mnodes/s]
[Jul 21 20:46:20 UTC] 21 OGR packets (21 work units) remain in (memory-in)
[Jul 21 20:46:20 UTC] 3 OGR packets (3 work units) are in (memory-out)
[Jul 21 20:52:50 UTC] Completed OGR stub 24/17-4-8-38-1 (2,356,770,834 nodes)
0.00:06:29.73 - [6,047,126.58 nodes/sec]
[Jul 21 20:52:50 UTC] Loaded OGR stub 24/17-4-9-5-27
[Jul 21 20:52:50 UTC] Summary: 28 OGR packets (78.08 Gnodes)
0.03:40:38.99 - [5.89 Mnodes/s]
[Jul 21 20:52:50 UTC] 20 OGR packets (20 work units) remain in (memory-in)
[Jul 21 20:52:50 UTC] 4 OGR packets (4 work units) are in (memory-out)
[Jul 21 21:26:55 UTC] Completed OGR stub 24/17-4-9-5-27 (12,397,399,323 nodes)
0.00:34:04.26 - [6,064,480.57 nodes/sec]
[Jul 21 21:26:55 UTC] Loaded OGR stub 24/17-4-9-5-26
[Jul 21 21:26:55 UTC] Summary: 29 OGR packets (90.47 Gnodes)
0.04:14:43.25 - [5.92 Mnodes/s]
[Jul 21 21:26:55 UTC] 19 OGR packets (19 work units) remain in (memory-in)
[Jul 21 21:26:55 UTC] 5 OGR packets (5 work units) are in (memory-out)
[Jul 21 22:02:36 UTC] Completed OGR stub 24/17-4-9-5-26 (13,038,492,435 nodes)
0.00:35:41.04 - [6,089,782.57 nodes/sec]
[Jul 21 22:02:36 UTC] Loaded OGR stub 24/17-4-9-5-24
[Jul 21 22:02:36 UTC] Summary: 30 OGR packets (103.51 Gnodes)
0.04:50:24.29 - [5.94 Mnodes/s]
[Jul 21 22:02:36 UTC] 18 OGR packets (18 work units) remain in (memory-in)
[Jul 21 22:02:36 UTC] 6 OGR packets (6 work units) are in (memory-out)
[Jul 21 22:47:13 UTC] Completed OGR stub 24/17-4-9-5-24 (16,282,726,284 nodes)
0.00:44:36.38 - [6,083,852.79 nodes/sec]
[Jul 21 22:47:13 UTC] Loaded OGR stub 24/17-4-9-5-15
[Jul 21 22:47:13 UTC] Summary: 31 OGR packets (119.80 Gnodes)
0.05:35:00.68 - [5.96 Mnodes/s]
[Jul 21 22:47:13 UTC] 17 OGR packets (17 work units) remain in (memory-in)
[Jul 21 22:47:13 UTC] 7 OGR packets (7 work units) are in (memory-out)
[Jul 22 02:15:00 UTC] The keyserver says: "Happy cracking. Hail Eris!"
[Jul 22 02:15:10 UTC] Retrieved 24 OGR packets (24 work units) from server
[Jul 22 02:15:10 UTC] Loaded OGR stub 24/1-10-26-3-20
[Jul 22 02:15:10 UTC] 23 OGR packets (23 work units) remain in (memory-in)
[Jul 22 02:15:10 UTC] 0 OGR packets (0 work units) are in (memory-out)
[Jul 22 02:15:10 UTC] 1 cruncher has been started.
[Jul 22 02:44:18 UTC] *Break* Restarting...
[Jul 22 02:44:19 UTC] Saved OGR stub 24/1-10-26-3-20 (28.00% done)
[Jul 22 02:44:19 UTC] Summary: 0 OGR packets (---.-- nodes)
0.00:00:00.00
[Jul 22 02:44:19 UTC] 24 OGR packets (24 work units) are in (memory-in)
[Jul 22 02:44:19 UTC] 0 OGR packets (0 work units) are in (memory-out)
[Jul 22 02:44:21 UTC] The keyserver says: "it was boiling a run to the sea
(dbaker)"
[Jul 22 02:44:23 UTC] Retrieved 24 OGR packets (24 work units) from server
[Jul 22 02:44:23 UTC] Loaded OGR stub 24/24-20-2-16-1
[Jul 22 02:44:23 UTC] 23 OGR packets (23 work units) remain in (memory-in)
[Jul 22 02:44:23 UTC] 0 OGR packets (0 work units) are in (memory-out)
[Jul 22 02:44:23 UTC] 1 cruncher has been started.
Your are keeping your buffers in memory. They are being lost when you shut down/restart.
I would suggest that your remove the "nodisk" option from your ini file.
Option 2 then option 1 to NO if you are using the interactive config route.
You did get some work returned though.
<< [Jul 21 20:08:28 UTC] Sent 23 OGR packets (23 work units) to server
Nice rate, BTW.
viz
I changed it back to keep buffers on hard drive.
Cool I guess dnet is taking longer to update than before.
thanks guys.
It looks like the 19th and 20th counted for yesterday because the 19th and 20th still are not there. Oh well.
