Originally posted by: bryanW1995
lol
the problem is that you would need a multi-core monitor to go with the others...
Originally posted by: keysplayr2003
Modular design. Very smart. R700 will be value, midrange and high end all depending on how many cores are placed on the card. They don't have to waste time of different GPU designs. One size fits all, it's just how many on board that determines the performance bracket/price. This of course all depends on how well the driver is designed (CrossfireX) and how efficient they can make it. I mean, you could have 4 R700 cores on one card, but does it offer the performance of 4 R700's? Or is it maybe 3.1x the performance of a single R700? There is a percentage of overhead cost (for both Crossfire and SLI) with each additional GPU. Unless that is all changed.
This should be the most interesting thing the graphics world has had to offer in a long time if this bears fruit.
Looking forward to it.
Originally posted by: Mech0z
Will these cards require PCI 2.0 ? Because I am buying a new computer very soonish and it would be nice to be compatible with those cards when they get out!
I think they might just for power usage. I see two extra power connectors on board. So 150W from the slot and an addition 150 from both power connectors. If a single RV670 uses about 130W to 140W then the PCIE2 @ 150W and a single connector @ 75W wouldn't be enough (225W total). They'll need the 2nd 75W connector to meet the "supposed on my part" 260W to 280W with a cutting it close total of 300W totally available.
So yes, I think it will need PCIE 2.0 and two power connectors. No less.
Either that, or a power brick if using a PCIE 1 slot.
I read somewhere the other day that r680 is supposed to be slightly lower clocks than 3870. Keys, I thought that you told me that 3870 was only 105w? maybe it was john...all you mods run together...😉Originally posted by: nullpointerus
Maximum power that can be supplied to video cards by various sources:
A. PCI-E (1.x) 16x Slot: 75W
B. PCI-E (2.0) 32x Slot: 150W
C. PCI-E (1.x) 6-pin Connector: 75W
D. PCI-E (2.0) 8-pin Connector: 150W
B + C + D = 375W, but most people will only manage 2x6-pin connectors off the PSU
I thought RV670's power usage under load was about half the HD2900XT (i.e. 66W avg. vs. 133W avg.) due to the die shrink, and the HD2900XT is PCI-E 1.x w/ the same two power connectors as this 3870 X2 card, for total supported maximum power draw of 225W (at stock clocks only).
I also wonder whether clocks might be slightly lower than stock 3870 single-GPU cards due to cooling issues. Remember the 7950GX2 used mobile derivatives of the 7900GTX core w/ lower clocks than the 7900GTX. Lower 3D clocks means less heat, but more importantly lower power consumption under load.
My guess is the 3870 X2 will work fine with the same 225W total (PCI-E 1.x slot plus 2x PCI-E 1.x connectors) at stock clocks.
Regardless, buying PCI-E 2.0 is probably a sensible decision right now if not cost prohibitive (i.e. < $40 premium).
well, really 8800 series cards use this with their clusters, right? 4 for 8800gt, 5 for 8800gts 640 and 6 for gtx/ultra, why couldn't amd do something similar with r700?
Originally posted by: taltamir
EDIT: I don't think there is any chance that the R700 is modular though.
1. There are pictures showing two module connections (ie, two squares containing die etc)
@thilian: that is a possibility... is the R680 supposed to be MCM?
for it to be crossfire on one card it has to have two phyiscal boards... the pictures I have seen show two ... "squares" on one plastic board (not die, but the modules that go in a socket). So, duel socket board.... which means it COULD potentially use unified ram archetecture or some other advanced stuff and potentially not crossfire.
