Apparently you missed the review at Sudhian as well as a few others who couldn't completely recommend the 8RDA+.Originally posted by: Mem
I`ve seen more then ten reviews of the Epox 8RDA+ and Club OC is the first to give the 8DRA+ bad review,as for the software packs they`re nick picking in my books since Epox always have some free software with their boards,whether or not it`s great is besides the point since the motherboard in the end is what you buy it for.
I'm not knocking EPOX or this board specifically, many people are extremely happy with it, have done amazing overclocks and are running 100% stable. Unfortunately others are frustrated by myserious crashes, instability at rated speeds, and BIOS corruption issues. I'm only pointing out that as with anything YMMV.Our stability tests are designed to stress a motherboard and test its ability to remain stable under harsher conditions than are normally imposed by testing. Our Epox board, unfortunately, was schizophrenic from the beginning....
Periodically (and without warning) the board would die at reboot and absolutely refuse to POST for a period of time ranging from several minutes to as long as two hours....
Is the 8RDA+ a good board? Sometimes. It overclocks well and when it runs, it runs great. Is it a board we'd recommend? Not really. While our problems with the board are likely to be isolated, our difficulties obtaining customer service may not be, and we're not willing to recommend a board when we aren't sure the company that manufactured it will stand behind its end users.
Originally posted by: SeekingTao
Can we talk about the FIC AU11 here as it is designed by Epox/FIC and 99% identical? I am buying it instead of the Epox 8RDA+.
If you got the 8RDA+ you might want to remove the northbridge heatsink first thing, and replace the stock phase-change thermal pad with some Arctic Silver 3 (do a test fit, it takes a lot to fill the gap because the northbridge is a little recessed in the center). Personally, I opted to upgrade the northbridge cooling to one of these. I have a low-profile heatsink that will go nicely on the southbridge too (there are pinholes around the SB for attaching heatsinks with spring pins too).
Originally posted by: Stephan28
🙂Onto the cooling issues:
1st of all just so I and everyone else is aware.....Does changing out the stock Northbridge Heatsink void the Epox warranty? I realize that it is a "mod" but just wanted to be sure.
Is there a fan/heatsink combination out there that will plug and play? I read something about the vantec iceberg cooler somewhere.
Will the same unit fit both the North and the South Bridge?
What are the recommendations for the CPU as far as cooling goes. I am planning on using a ThermalTake Volcano 7+
That's because it's not a word, it's an acronym. 😉 MOSFET - metal oxide semiconductor field effect transistor. Personally I think it'd just be easier if people referred to them as the "power transistors".Originally posted by: cowdog
mophsets (spelling??, remembering how to spell that bewilders me).
Originally posted by: mechBgon
I'm pretty sure my warranty's void since I used my Dremel and some sanding discs and levelled off my northbridge a tad 😀 before putting on one of these. BTW you can also get a gold-tone version of this from Newegg: link
A note about the southbridge: I was all set to put my stock northbridge heatsink on my southbridge until I noticed that this would prevent the use of a longer PCI card in several slots (my SCSI card, for instance). I rummaged around and found the heatsink that comes with a Globalwin FAC08 I'd bought a long time ago, and hey, its pin spacing matched 😀 This seems to be working out really well and it's short enough that it doesn't interfere with a normal 32-bit PCI card (a 64-bit card's tail section might still interfere).
DRIVER_IRQL_NOT_LESS_OR_EQUAL
Does the SB chip get hot enough to warrant a cooler even when not overclocking? I only plan to overclock the FSB to 166 on my Tbred "B" 2100+. Will I need to add a cooler to the SB first?
Originally posted by: Iron Woode
I got my 8RDA+ today. Rev 1.1. What are the revisions out there?
For the record, my southbridge got quite hot, as in, too hot to leave my finger on it for an indefinite period. Is it out of spec? Probably not, but keeping its temperature lower can't hurt 😀Originally posted by: SeekingTao
Originally posted by: TAL0N
Apparently you missed the review at Sudhian as well as a few others who couldn't completely recommend the 8RDA+.Our stability tests are designed to stress a motherboard and test its ability to remain stable under harsher conditions than are normally imposed by testing. Our Epox board, unfortunately, was schizophrenic from the beginning....
