Originally posted by: Nikepete
Do these boards support the new Thoroughbred CPUs ?
Originally posted by: Blain
The FedEx man should be dropping off my 8K5A3+ today. It looks like it will be a good match for my Corsair PC3000C2
My water block and system are all ready and waiting!
Did I read the 8K5A3+ BIOS flash instructions right...
It detects and updates via the internet?![]()
Originally posted by: Athlonstein
I just received an 8k5a2+ today and noticed the Nothbridge hs is rectangular (link below shows a pic), most reviewed pics show it being round.
8k5a2+
Anyone know if this before or after the round hs? Better or worse?
Anyway, does it really make any good to use a RAID on a single Hard drive?
I have an Alpha 8045 that I would like to use with this board. What do they mean by "shoulder washers"? Are they talking about the little plastic washers that come with the little plastic nuts? If so, I have no idea why they wouldn't want you to use them.Yes, this board is Alpha 8045 safe. You do not need any modification to fit an alpha 8045. The four HSF mounting holes around the socket are small ones and not grounded. Thus, potential Alpha 8045 users should not use shoulder washers.
Originally posted by: williamkusumo
By the way, I was asking about the difference between 8K5A2 and 8K5a2+ because their price are about $20-$30 apart. Are those extra things on 8K5A2+ worth that much?
William
And regarding the board monitoring CPU temp via the diode on the XP+ proc., what is considered the max safe temp for overclocking if youre looking at that?? I understand 100C is the critical shutdown point, but whats the temp that you should stay away from when overclocking???
What's with the new 8K5A2+b I just saw on Newegg (other that the extra $50)?
What is the main difference between 8k5A2 and 8k5A2+?
Is it only the presence of RAID and the number of PCI bus or DDR RAM Slot?
Anyway, does it really make any good to use a RAID on a single Hard drive? As far as I know, RAID increases performance by representing several Hard drives as one entity and divide the work on each Hard drive.
Please advice,
William
Originally posted by: Insane3D
Originally posted by: MaxDSP
Im thinking of buying the 8k53+, XP 1400+, and 256-384 MB PC2700 RAM. what are the best places to buy this stuff from? For the RAM, crucial has a lifetime warranty on its chips, so should i pay the extra amount and go with crucial?
Ok, first of all, before you go with the 8K5A3+, let me ask you a question. Do you need 4 RAID IDE ports vs the normal two on the 8K5A2+, and do you plan on filling up more than three memory slots with Registered DDR? The only difference between the 3+ and the 2+ is one extra memory slot that would require registered memory to fill all four, and the extra two IDE ports. If you don't plan on doing a 4 HD RAID array, the 8K5A3+ seems like overkill for you.
Now, I'm assuming when you say 1400+, you mean the 1.4ghz 1600+. So I'll quote prices on the 1600+ since there is no such CPU as the 1400+. Also, all memory that I have seen, even generic, usually comes with a lifetime warranty...that's not exclusive to Crucial by any means. One other thing with the memory, do you plan on running speeds in excess of 166mhz? If not, regular Samsung DDR will do you fine. If you plan on running really high speeds, like 180mhz +, you will need to get some of the more expensive Corsair DDR.
Here's a nice little config for you...
Epox 8K5A2+ @ Mwave - $99.51
Athlon XP 1600+ @ Newegg - $56 (Free Shipping)
512mb Samsung PC2700 @ Kommax - $126
Total: $281.51
Total: $281.51
Excellent, thanks for the advice Insane. The only reason I thought about the 3+ was because I *may* want a RAID array in the future, but not too sure. I guess Im better off saving money and just getting a RAID card if I decide I want it. Now I just need to look at my last months Visa statement of $1,061 and see if I really need this![]()
Total: $281.51
The 8K5A2+ has RAID, just the normal two ports instead of four....
The only reason you would need the 3+ is if you wanted to do a RAID array of more than two HD's.
Originally posted by: Roughee
Can anybody tell me the disadvantages of the 8K5A2 ? All i know is that there is no Raid On-Board which i still don't need.
But is there anything else i should know? Something that decreases the overall performance?
thx 4 reply.
Please everybody forgive me, i only read the first page and posted my request.
Now that i was looking for my post i found the answer above.
I promise i will look more and more careful for the number of pages in a thread in the future.
Sorry,
Roughee
