Originally posted by: WizardNJ
Sounds like something is loading down the +12 volts.
The motherboard does not regulate the +12 volts but it does use that voltage (creating a load).
How many fans, hard drives, cdrom, etc in the machine? Try running just the power supply, one hard drive, and only videio card installed (with ram and cpu of course). See if voltages fluctuate. If they don't then start adding one device at a time until you can figure out what is loading it.
My True Control 550 is rock solid.
Originally posted by: duncan888
I am considering either this Aopen board or the MSI,
can you tell me if the AOpen as the option to automaticaly shut down the computer if the temperature of the CPU is reached a some point, or any other similar function which protects overheating.
Thanks
leave the case open for ventilation and remove any case fans from the motherboard and check voltages for stability. I've found that most power supplies will run slightly under 12 volts (around 11.8 to 11.9 range) but they should not be varying.
I bought the True Control 5550 because I wanted to see all the voltages at their rated voltage and the True Control allows adjustment of +12, +5, and +3.3 volts.
Originally posted by: Scroatdog
I'll give it a try when I get home.
Out of curiosity, do you have any fans connected to the SYSFAN3 connector??? I certainly don't like the idea of the rail appearing unstable to the mobo, and the fact that both MBM5 and SilenTek go crazy and tell me my system temp is -47 and CPU reached 205C. Something is either not right with the on-board monitoring, or the mobo itself.
BUt if you're reporting a stable +12v, I've got to assume it's my mobo. Hopefully disconnecting the exhaust fan from SYSFAN3 will reveal something. If not, RMA here I come.
Hey wizardNJ
is there any temperature shutdown settings in the bios? wouldnt a bios setting be more reliable than software auto shutdown?
what kind of overclocking speeds can you reach on your components, they are similar to what i am thinking of getting
Thanks
Originally posted by: KoolHonda
Exactly where did you nick the mobo with the screwdriver?
Wizard,
Here is the latest. I unplugged the exhaust fan from the SYSFAN3 connector. Booting into the BIOS, I went to the temp/voltage, and it showed 11.67-11.55
Let me know if you think it's a board problem, and I'll RMA it and either get another Aopen, or the Abit IC7-G
