Originally posted by: dullard
Originally posted by: JLee
I've heard that Office 07 is a significant improvement over previous versions..is that wrong?
With Word, it isn't too different. The SmartArt is vastly improved, but still dreadfully limited (what I mean is that it looks really good, but if you want to customize it, you are likely screwed). The equation editor is improved, but it screws up your old equations from old versions and you can't load the 07 equations into older versions. The styles selection was completely revamped, but a bit more powerful and a lot more buggy. Native PDF use is a good thing, although there were add-ins for older versions that worked just fine. Other than that, I don't see much change other than the screen-wasting ribbon.
With Excel, you get no real benefits that I can see other than slightly more attractive graphs. However, that ribbon gives you major headaches. Instead of clicking on a graph and getting one tabbed window with everything you need, you now must alternate between two ribbon tabs and a dozen of difficult, confusing, and slow to use icons to attempt to change things. For example, suppose you want to put in axes titles:
[*]In old versions you click on the graph and type in the titles in one window.
[*]Now, you click on the graph, click layout, click axes, click primary horizontal axis, click show, click axes title (if the ribbon reset to home, then first click layout AGAIN), click primary horizontal title, click title below axes, the graph doesn't update, so move it to make room, click on the title, type the horizontal title, click axes, click primary vertical axis, click show, click axes title (if the ribbon reset to home, then first click layout AGAIN), click primary vertical title, click title below axes, the graph doesn't update, so move it to make room, click on the title, type the vertical title, repeat with all other axes (if the ribbon reset to home, then first click layout AGAIN and AGAIN).
Originally posted by: SunnyD
It works fine for what it's designed for. People complain about the stupidest crap... just like Vista doesn't work worth shit... :roll:
See above Excel example. THAT is why people hate the ribbon. Taking a 30 second task and making it a 5 minute task is worthy of complaining. Do that dozens of times a day and you realize that it isn't stupid crap.
Edit: I forgot stupid placements in my rant. In older versions, to add a row or column, you clicked insert then the appropriate row or column menu option. Now, you click insert on the ribbon and nothing is there. You have to click HOME to insert a row. Why the fuc& didn't they put the insert row or insert column in the INSERT ribbon?
