Could it be a corrupt OS due to the crash?
Yeah, toss a spare drive in if you have one and reload the OS. that would tell you if it's the OS causing the crash.
This is why I have a velociraptor in the drawer with a good copy of 7 running on it. I also have the good running version on a TIB file (Acronis) in case it gets hosed. It's also nice for testing to get back up and running fast as the SAS BIOS takes a bit of time to initialize.
Just grab a SATA drive, load your fav OS on it with a folder with all your testing goodies and you're golden. I like Win 7 because I can switch hardware and it does not mind much particularly if going between ATA and AHCI mode, etc.
I'm still old school, I keep a spare drive and winXP images in ghost format! 😱
any aftermarket software that checks that ? Also, it will run even 3.9 for 12-18 hours before it locks up
Ghost is good but I converted to Acronis a few years ago when (Ghost) would not support partitions > 999GB. I ran a fairly early version in DOS. It also stop recognizing high end hosts. 🙁
[IMP]http://pics.bbzzdd.com/users/markfw/speedfan_920_333.JPG[/IMG]
OK, here is a speedfan screenshot, and the latest. I left everything in bios alone, except blck to 666, so I have been at 3.33 ghz for a day now, no worries. And coretemp says my cpu temps range from 49 to 53.
I think I wait for a day and try 180. Maybe it didn;t like to vtt and pll that aigo told me to add....
Fixed...I'm sure you mean 166 as 666 would be a record setter. 😉
Fixed...
So what do you think ???
Maybe it didn;t like the vtt (1.3) and pll(1.86) that aigo told me to add....
Maybe that was the whole problem....After a few days, will try 3.6.Can't say from personal experience (I'm still on 775), but vtt looks pretty high to me. From OC guide here, "absolute maximum" is recommended at 1.21 (but I've seen higher from a lot of people).
edit - looks like Ruby beat me to it. Good to have backup though!
OK, here is a speedfan screenshot, and the latest. I left everything in bios alone, except blck to 166, so I have been at 3.33 ghz for a day now, no worries. And coretemp says my cpu temps range from 49 to 53.
I think I wait for a day and try 180. Maybe it didn;t like the vtt (1.3) and pll(1.86) that aigo told me to add....
Seems like it was a memory problem all along. It doesn't want to run @ rated speed. Not sure why it was fine for months,
In the bios, there is a setting for the memory divider. I got 1600 memory (runs 200 x 4 I think) rated, but right now its only running 135 x 4 I think (shows ddr 1080). Its all a little confusing to me, maybe someone else can set me straight if I am wrong.How do you test a DDR3 kits rated speed? I know how to do it on a 775 system. e.g. 500fsb will be synced with a DDR2 1000Mhz kit or aka 1:1 but what about DDR3?
