Originally posted by: dclive
Originally posted by: Gagh
Hm.. i think i might be having a similar issue here. Thought it might be related to the issues ive been having with my a64x2, but after screwing around with the amd drivers, the problem persists. I run...
AMD a64x2 4800+
MSI k8n nforce 4 platinum sli
2gig OCZ ddr400 (running default spd timings)
two EVGA geforce 7800 gtx cards runing sli
Audigy 4 platinum
OCZ 600 wat powerstream psu
windows xp sp2 (all updates installed, up to date nforce, nvidia and amd drivers, cd drivers for the audigy, as the creative driver update just breaks things)
Now the game ive got issues with is Eve-Online. All was running well with the game till this past week, where a new patch for the game was released, which in turn introduced the jerkiness issue with the x2 processor to the game. Setting affinity fixes it, but since then i get random BSODs in that game, could happen at login, could happen after playing for 4 hours.. totally random. Whenever it happens my screen will either go black or freeze, followed by popping/thumping noise from my speakers, and then the blue screen for 5 seconds before it auto-reboots. Nothing i can think of to do has made any difference, and i dont get to see the blue screen for more then a fw seconds before the reboot. From what i can gather they have been page fault issues.. I dunno. Ive stability tested it with prime95 in both the memory and cpu tests with no issues, which makes me think my hardware is fine.. that and the fact that i had no issues prior to the beginning of this week. Any ideas?
Update all the drivers & do all Windows updates. If the problem continues, send me an e-mail with the .cab file output from MPSReports (see my .sig) and send me the minidumps made AFTER you updated all your drivers, found in c:\windows\minidump.
All drivers , save for the sound card drivers (as the new ones cause all sorts of issues) are up to date as of yesterday, as is windows. Ive got a few minidumps in that folder, not sure what ones are new, or old. Should i just wipe that folder and wait for a new error to ensure that minidump is the correct one?
