I thought it was clear that I was talking about the 34nm Vertex 2 drives from context, sorry if I jumped a bit too far there.Still Indilinx, I think. I guess you meant the old Vertex 2 SSDs?
Sure you get about 215mb/s instead of 250mb/s if you use a random 2mb sequential read IOmeter run, but I wouldn't consider that a problem - write is a lot harder affected, but still if you know about the compression and base your opinion of the drive on the real world data you'll end up with a perfectly fine drive.. it's just not the second coming like the marketing benchmarks would want us to believe, but what ever is.their sequential read speeds are only about 200 MB/s for most real data
Which as far as I'm aware of only happened after benchmarking and/or stresstesting the drive, which is hardly a normal useage szenario.. and would still be about the niveau of a Intel drive.and they have a bug/feature where the sequential write speeds can drop to 60 or 70 MB/s for a week after they determine, in some unspecified manner, that they have had a lot of writes.
LOL! You have an odd definition of perfect. To most people, something that has flaws is by definition, imperfect.
And come on! Only aware of after benchmarking? Are you serious? How else would it be measured, by telepathy?
And you seem to have a strange reading ability, considering that "perfectly fine" is hardly the same as "perfect" in modern english..LOL! You have an odd definition of perfect. To most people, something that has flaws is by definition, imperfect.
Umn, I assume by writing real data to the drive and seeing that it's not impeded? If you're arguing that you need to benchmark a drive with 4k random data at a QD of 32 to find out how fast sequential write is, you should think about that once more.And come on! Only aware of after benchmarking? Are you serious? How else would it be measured, by telepathy?
No actually "benchmark" is defined as "a standardized problem or test that serves as a basis for evaluation or comparison (as of computer system performance)" which is at least for hard drives usually a bit more than one particular metric, so it was pretty clear from context. If you want to misinterpret things well nobody can stop nitpickers anyhow.As for benchmarking, it means measuring the performance.
Sorry if english is a bit more complex than that, I'll try not to confuse you any more with phrases. God forbid someone uses "perfectly normal".That is ridiculous. If you do not mean perfect (or functioning perfectly) then do not write "perfectly". Write fine, or okay, or satisfactory, or sufficient. If you write perfect when you refer to something that is flawed, then you misusing the language.
It's well known that if you hammer SF drives with a large amount of random 4k writes in a short period of time (which you realistically only do when benchmarking a drive; no client usage pattern is that stressful) it'll reduce it's performance.. that you can easily check by writing a large sequential amount of data to it. If you get that performance degradation without running any benchmarks (or stresstests, or any other unrealistically stressful application/test - sorry I almost forget I have to spell everything out for you) then come back.As for your absurd claim that Sandforce SSDs only throttle the performance after they have been benchmarked, since you are only aware of the lower speed being measured after someone actually measured it, well, enough said.
Yeah I'm terribly sorry for using such.. umn advanced phrases and not limiting myself to basic english :/You can keep pretending that you did not write something which was misleading and incorrect, but we know the truth. A flawed SSD, as are all Sandforce SSDs, is not "perfectly fine". They may be adequate, but they are far from perfect.
This sounds interesting. As much as I dislike OCZ's handling of this matter, I also dislike frivolous or borderline frivolous lawsuits. I'm wavering on whether this is frivolous or not. In the end, OCZ's gonna pay in reputation, no matter whether this lawsuit wins or loses, and the loss most consumers will face is, for the most part, negligible. Well, put it this way. Fraud, I can see. But as a class-action lawsuit? That sounds... unnecessary.As a result of these allegations, the Rosen Law Firm, P.A. is investigating a potential class action lawsuit against OCZ for violations of certain consumer fraud laws.
The phrase "perfectly fine" does not imply perfection. It is a standard phrase used descriptively;
Yeah sorry we really didn't know that we couldn't use standard english phrases that have been in use for decades. It's really horrible that words can mean different things in different context, if you send us your personally approved canon we'll make sure to only use that. My ba.. sorry ungoodIt is misleading slang, not a standard phrase. Perfectly fine does imply perfection. Words have meaning. If perfection is not implied, the phrasing should be "fine" or adequate, or satisfactory, or sufficient, or any of a number of other words that might describe the quality. If perfection is not being described, then the word perfectly should be omitted.
Playing the semantics game is fine if it actually gets you somewhere and it means something. As it stands, you know what he meant.
Semantics may be a "game" when we are talking about fine shades of meaning of a word, but semantics is hardly a game when someone writes a word but means the opposite.
I only know what he meant after he clarified that although he wrote "perfectly", he actually did not mean perfectly at all.
And your continued protestations that we should let the matter drop would be less disingenuous if you actually stopped posting about it.
You are acting pretty childish.
How do you know whether I am pretty if you have never seen me?
Ah you shouldn't waste your time to argue with him. I mean his whole argument is based on "a word can have only one meaning - independent of it being a adverb or adjective or used in different context" - but then I'm hard pressed (note: No, I wasn't killed by a press) to believe he was serious with his last posts.I should have known not to use another adverb.
